dread question..
It also depends on which version you use. The Mk.IV has a larger weapon but slightly smaller shoulder than the standard Mk.V of GW dreads. Just make sure that if you use the Mk.IV you do so on both sides. It looks goofy to have a Mk.IV gun and Mk.V DCCW.
The Dreadnought that comes with the AoBR set is the same size as the plastic Dreadnought kit. The weapons that fit the normal Dreadnought kit fit perfectly with the AoBR Dreadnought. The only problem is that the holes on the weapon arms are bigger than the pegs so you will have to glue them as they won't stay attached with a friction fit. I have TLLC & Missile Launcher arms on my AoBR Dreadnought and with the exception of the exhaust pipes being shorter, you can't tell the difference from the normal plastic kit. I also put the Multi-Melta from the AoBR Dreadnought on my normal Dreadnought and it looks perfect. So if you get the right Dreadnought arms (Mark V) from Forge World they should fit and look good w/out any problems.
