caboosebe Posted November 7, 2010 Share Posted November 7, 2010 I want to model some of my bases with desert sand. Do I really need to buy a cup of desert sand or can I use regular white sand and paint it? If yes, what paint should I use? Thank you for your time Your friendly nutcase, Caboose Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/ Share on other sites More sharing options...
Gurth Posted November 7, 2010 Share Posted November 7, 2010 You can certainly paint sand, no problems there. Just thin your paint so it flows well, use a relatively big brush, and keep in mind that the sand will soak up the paint quite well so you're going to need a fair amount (hence the thinning :o). Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2555866 Share on other sites More sharing options...
caboosebe Posted November 7, 2010 Author Share Posted November 7, 2010 And what color do you suggest? surely sunburst yellow is too bright, no? Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2555958 Share on other sites More sharing options...
silverneil Posted November 7, 2010 Share Posted November 7, 2010 Try desert yellow Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2555994 Share on other sites More sharing options...
Firepower Posted November 7, 2010 Share Posted November 7, 2010 A common approach when primed black: Bubonic Brown Drybrushed Vermin brown Drybrushed Bleach Bone If you're basing after priming (which I don't recommend, seeing how primer helps add to the bond and resilience) You can probably get by just soaking it in Vermin and drybrushing Bleached Bone over it. Not 100% sure though. Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2555997 Share on other sites More sharing options...
GhostLegion Posted November 7, 2010 Share Posted November 7, 2010 I used to go with something similar to what Firepower describes. Now, I prefer a Bestial Brown undercoat with a Desert Yellow overbrush. Final layer for this is a moderate to heavy drybrysh of Vallejo's Iraqi Sand (#70819). The result is pretty nice in my opinion. Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556004 Share on other sites More sharing options...
caboosebe Posted November 7, 2010 Author Share Posted November 7, 2010 Ok thanks all, I think i'll do a few test bases with all the diffrent suggestions and see what comes out best Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556007 Share on other sites More sharing options...
Gurth Posted November 7, 2010 Share Posted November 7, 2010 And what color do you suggest? surely sunburst yellow is too bright, no? Any sand-coloured paint will do, depending on what you have in mind: dark or light, yellow or red sand, and so on. My own method would be to paint it in the sand colour I'd more or less like it to be, then apply a wash* of a darker shade and once that's dry, drybrush with a lighter colour. * No, not the transparent paints GW sells under that name, but a proper wash: paint thinned so far it runs into all the cracks but does not cover the higher detail. Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556103 Share on other sites More sharing options...
Solid Zaku Posted November 7, 2010 Share Posted November 7, 2010 Hi Caboose. Here's some advice. I'm a desert dweller. I've lived in one all my life, and I figured using desert sand was the easiest thing to use ever. It's plentiful, is totally dry (in other words: took paint well) and was, of course, desert tan. I was wrong. Way wrong. When I put it on the base, it looked just silly. There was no definition to the base, the color of the black base bled completely through, and it fell off like it wasn't even glued on. Don't fret though, desert bases are doable, just don't use sand, for the love of the Emperor Enthroned. GW Basing Sand, used after the model is finished, works wonders. Just don't prime it, finish the model, color the base with Calthan Brown, and apply the glue and GWBS. It looks just like I wanted. There is the depth of the 'rocks' and differentiation in color. Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556109 Share on other sites More sharing options...
Obliterator Posted November 7, 2010 Share Posted November 7, 2010 I want to model some of my bases with desert sand. Do I really need to buy a cup of desert sand or can I use regular white sand and paint it? If yes, what paint should I use? What kind of desert are you looking for? On Terra alone you got tan deserts, reddish deserts, white ones, etc. On other planets you'll most likely encounter different colors as well (just google 'desert' and look at the variety of images you get). Depending on the look you're after, you'll probably need other colors. For my bases I use modelling sand, like the GW product, or Woodland Scenics and the likes. When you use real sand, the grain is often too large to represent sand in a 28mm setting, you'll often end up with pebbles the size of a normal man's fist. For my Salamanders I wanted to get a sort of white desert/wasteland scheme to get a nice contrast with the green. I basecoated the sand with Callthan Brown, and drybrushed with Graveyard Earth, Dheneb Stone, Bleached Bone and Skull White. I also applied some dry looking grasses. The edge was painted in pure Dheneb Stone. Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556145 Share on other sites More sharing options...
caboosebe Posted November 7, 2010 Author Share Posted November 7, 2010 It would be for my Thousand Sons, want to put them in an 'Egyptian' theme, so probably desert sand you see around the pyramids. Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556215 Share on other sites More sharing options...
True Thorn Posted November 7, 2010 Share Posted November 7, 2010 So a yellow/white sand tone? Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556225 Share on other sites More sharing options...
caboosebe Posted November 8, 2010 Author Share Posted November 8, 2010 yes something like that ^^ Link to comment https://bolterandchainsword.com/topic/214654-desert-sand-paint/#findComment-2556461 Share on other sites More sharing options...
