Tsavong Lah Posted November 11, 2010 Share Posted November 11, 2010 Hey, If you were to toss a squad of Long Fangs and Logan Grimnar into a Rhino, would any of them be able to fire out of the top hatch when the Rhino has moved? I'd think so, but since Heavy Weapons don't normally come with Relentless I'm not sure how that interaction works. Link to comment https://bolterandchainsword.com/topic/214923-long-fangs-using-the-rhinos-fire-point/ Share on other sites More sharing options...
postal105 Posted November 11, 2010 Share Posted November 11, 2010 umm as Logan is in TDA you cant put him in a rhino if i am remembering correctly Link to comment https://bolterandchainsword.com/topic/214923-long-fangs-using-the-rhinos-fire-point/#findComment-2559698 Share on other sites More sharing options...
Tsavong Lah Posted November 11, 2010 Author Share Posted November 11, 2010 Oh, that's right. For some reason I wasn't thinking of Logan as a real Terminator. Thanks! Link to comment https://bolterandchainsword.com/topic/214923-long-fangs-using-the-rhinos-fire-point/#findComment-2559700 Share on other sites More sharing options...
Sarapham Posted November 11, 2010 Share Posted November 11, 2010 And even if you could it would be a insane amount of points for something that is almost outshot by a razorback and definately by a simple predator. Link to comment https://bolterandchainsword.com/topic/214923-long-fangs-using-the-rhinos-fire-point/#findComment-2559720 Share on other sites More sharing options...
TiguriusX Posted November 11, 2010 Share Posted November 11, 2010 Nice outside the box thinking on that one. Best combo I have heard for LFs and Logan is the DP delivery system backed up by GHs with plasma guns to "rescue" Logan on turn 2. Other LF/Rhino ideas simply put the LFs in a rhino w/o Logan. If the Rhino doesn't move you can unload 2 weapons. The choices are minimum sized LF squad or 4 special weapons to make them versatile. If you go 4 then the loadout is 2xMM + 2xPC b/c the razorback can already bring a LC and you don't need to move around and get in position with the MLs. MM for AV/MC and PC for everything else Link to comment https://bolterandchainsword.com/topic/214923-long-fangs-using-the-rhinos-fire-point/#findComment-2559760 Share on other sites More sharing options...
Skalver Posted November 13, 2010 Share Posted November 13, 2010 Nice outside the box thinking on that one. Best combo I have heard for LFs and Logan is the DP delivery system backed up by GHs with plasma guns to "rescue" Logan on turn 2. Other LF/Rhino ideas simply put the LFs in a rhino w/o Logan. If the Rhino doesn't move you can unload 2 weapons. The choices are minimum sized LF squad or 4 special weapons to make them versatile. If you go 4 then the loadout is 2xMM + 2xPC b/c the razorback can already bring a LC and you don't need to move around and get in position with the MLs. MM for AV/MC and PC for everything else Maybe I am misreading what you are suggesting but Razorbacks do not have fire points so you can't shoot out of them no matter what if you are suggesting having Long Fangs mounted in a Razorback that would be a very bad idea. Link to comment https://bolterandchainsword.com/topic/214923-long-fangs-using-the-rhinos-fire-point/#findComment-2561020 Share on other sites More sharing options...
Brother Nathan Posted November 13, 2010 Share Posted November 13, 2010 th razor has the weapons built in and is far cheaper. hes comparing a razor back with heavy weapons to sticking a dev squad in a rhino... Link to comment https://bolterandchainsword.com/topic/214923-long-fangs-using-the-rhinos-fire-point/#findComment-2561024 Share on other sites More sharing options...
