Meatman Posted November 12, 2010 Share Posted November 12, 2010 A quick one guys. I may have missed this in the rule book, but with an open topped transport such as the land speeder storm, can you move flat out 24", emergency disembark, taking the dangerous terrain test from the disembark, and still assault? Cheers Link to comment Share on other sites More sharing options...
SeattleDV8 Posted November 12, 2010 Share Posted November 12, 2010 No, BRB pg. 70 Tell us you may not embark or disembark from a transport that is going to or has moved flat out. Emergency disembarking can only be used if you are blocked by impassable terrain or enemy troops, and you still can not preform any other actions that turn if you do so. BRB pg. 67 Link to comment Share on other sites More sharing options...
Lord of Death Posted November 18, 2010 Share Posted November 18, 2010 would the unit die if the transport is killed after moving flat out then if they can not get out Link to comment Share on other sites More sharing options...
thade Posted November 18, 2010 Share Posted November 18, 2010 would the unit die if the transport is killed after moving flat out then if they can not get out See the new FAQ. Q: If a transport vehicle is destroyed in the same turn as it moved flat out what happens to any embarked models?A: They are removed as casualties. So...yes, if it's the same turn. No, otherwise. Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted November 18, 2010 Share Posted November 18, 2010 Emergency disembarking alllow you to ignore the rules about having to disembark within 2 inches of an access point (changing it instead to within 2 inches of the hull), it does not allow you to disembark at times when disemarking is not allowed (sucha when moving flat out) Link to comment Share on other sites More sharing options...
