[Artwork] I got powerarmoured by FFG
Colrouphobic
So FFG just put up news on Deathwatch a week or so back and I just noticed that one of my power armoured guys was in the newsarticle...
Here is a peek at it (did some more for the book, look out for it when the book is out)
http://fc05.deviantart.net/fs70/o/2010/320/f/e/fef8265413a64f7334179a1c72cdbc2a.jpg
Thats alot larger then it is in the book mond you,
here is the original article where the size is closer to printsize:
http://fantasyflightgames.com/edge_news.asp?eidn=1752
Cheers guys,
Incredbile. Did you use some computer painting techinique for the Space Marine?
Ran
define "computer painting technique"?
I paint using a graphic tablet (Wacom Intuos4) in a computer programme, typically photoshop or painter.
How many layers do you tend to work with mate? Ive found my last two pieces Ive almost lost count of the layers I have on the go and i cant get my rendering anywhere near as smooth as you.
I find that I am using less and less layers nowadays, and increase the size of the canvas and the dpi instead. To an extent I'm more painting over then using readjustment on layers. I mainly use layers to do colour corrections and lighting effects, such as desaturation or making an image warmer or colder....
Cool pieces Colrouphobic. but isn't the Plasma cannon a little small?
I mean when you look at the minis it looks so cumbersome
but again great work!
Cheers,
Yeah, for the images I made for Emperor Protects I got quite some references to use though. I also wanted to show a little more of the actual marine and in the pose FFG chose from the sketches I had to make the plasmacannon a little smaller to achieve that. It isnt that much smaller though, only shorter really. About a hand or two, by meassurment of the SM's hands..
  • 4 weeks later...
So the book is out, I made a total of four illos for it, one you seen (above) and I did one more Marine, one non-PA character called Rylus Darkscourge (not sure I can post it) and one icon for a tainted sect (I think).
Marine and Icon below:
http://th00.deviantart.net/fs70/PRE/i/2010/348/9/d/dw03_assault_marine_by_1mpact-d34vhi4.jpg
http://fc00.deviantart.net/fs70/f/2010/348/f/2/dw03_radial_of_chaos_by_1mpact-d34vhlq.jpg
I really like your work as always but i have to point out that the helmet of the marine in your new batch of work, well.... it looks a bit out of sorts, apart from that though he looks good.
I think the chaos symbol is fantastic though! :D
I think you might be right about the helmet... nothing like learning from ones misstakes :lol:
Scrap-meister, you might be right. I just get briefs with descriptions of what I need to paint and a mock-up name :)
It was called "Radial of Chaos" in the brief, and the description mentioned mechanicus cogs etc...
