ZONKEY Posted November 17, 2010 Share Posted November 17, 2010 just confirm when attaching a grenade to a dreadnought do you need to roll a 6 Link to comment Share on other sites More sharing options...
Legatus Posted November 17, 2010 Share Posted November 17, 2010 Yes, see page 73 in the BRB, "Walkers and Assaults". Unless the walker is stunned or immobalised at the beginning of the assault phase, you need to roll a 6 to hit with a grenade. Link to comment Share on other sites More sharing options...
Erasmus of Baal Posted November 17, 2010 Share Posted November 17, 2010 Yes, a 6 is needed. I didn't know that until I checked just now, actually. Also, this forum should be noted. Link to comment Share on other sites More sharing options...
Chaplain Lucifer Posted November 17, 2010 Share Posted November 17, 2010 Moved to the aforementioned forum section. Link to comment Share on other sites More sharing options...
thade Posted November 17, 2010 Share Posted November 17, 2010 You need a 6 to hit a Dread with a grenade in CC with one exception: if the Dread is Immobilized, you hit it with a grenade based on compared WS. If a Dread is Stunned, it loses an attack for the round but otherwise is unaffected. (IE you still need a 6 to hit it with a grenade if it is only Stunned.) Shaken does not affect a Dread in CC. Link to comment Share on other sites More sharing options...
Heimdall Skullcrusher Posted November 17, 2010 Share Posted November 17, 2010 You need a 6 to hit a Dread with a grenade in CC with one exception: if the Dread is Immobilized, you hit it with a grenade based on compared WS. If a Dread is Stunned, it loses an attack for the round but otherwise is unaffected. (IE you still need a 6 to hit it with a grenade if it is only Stunned.) Shaken does not affect a Dread in CC. As stated before, a stunned result uses comparative weapon skill (not needing a 6). But shaken does nothing. Check the rule book again. Link to comment Share on other sites More sharing options...
