slmellon Posted November 17, 2010 Share Posted November 17, 2010 Can the passengers of a vehicle with firing points fire if 1. The vehicle moves 12 inches, where the vehicle itself cannot shoot? 2. If the pops smoke? Link to comment Share on other sites More sharing options...
Grey Mage Posted November 17, 2010 Share Posted November 17, 2010 1) No- the rules specificly dissallow passengers firing if the vehicle moved more than 6". 2) Yes, the vehicles firepower has nothing to do with the passengers. Edit: For clarity, wether a vehicle fires or not has no bearing on the passenger, they can do different targets, etc- because they are still different units for all purposes. The only time this doesnt work is a specific rules exception- a shaken/stunned vehicle has the effect of not allowing passengers to fire while still on board the vehicle, though they can of course step out and fire as if theyd moved. Wich is one reason I think rhino bunkers with heavy weapons are a horrible idea. Link to comment Share on other sites More sharing options...
slmellon Posted November 17, 2010 Author Share Posted November 17, 2010 I found the anwser to 1 this morning, thanks though. I thought CREW shaken stunned had nothing to do with Passengers Link to comment Share on other sites More sharing options...
Iron Father Rik Posted November 17, 2010 Share Posted November 17, 2010 I found the anwser to 1 this morning, thanks though. I thought CREW shaken stunned had nothing to do with Passengers Crew shaken/stunned affects the living beings inside the vehicle. If the driver can get thrown about, bang his head off a bulk head and get knocked out for a few moments (or whatever other situation might be represented by this rule), why would the passengers not be equally susceptible? Grey Mage is right, passengers cannot shoot from within the vehicle if it suffers a crew stunned result, but they can bail out and shoot. I admit it seems a little off, if they are "stunned" inside the vehicle how are they able to climb out and act normally? I suppose the fresh air clears their heads. Link to comment Share on other sites More sharing options...
Heimdall Skullcrusher Posted November 17, 2010 Share Posted November 17, 2010 2) Yes, the vehicles firepower has nothing to do with the passengers. I've always thought this but have always been told differently. It seems like it is within the rules, but everyone argues that it should be that the passengers can't shoot anything since they can't see (though I always brought up the argument that you could have the passengers fire before the smoke). I've always acquiesced in the past but might fight a little harder next time. Is this generally accepted? Link to comment Share on other sites More sharing options...
Grey Mage Posted November 17, 2010 Share Posted November 17, 2010 2) Yes, the vehicles firepower has nothing to do with the passengers. I've always thought this but have always been told differently. It seems like it is within the rules, but everyone argues that it should be that the passengers can't shoot anything since they can't see (though I always brought up the argument that you could have the passengers fire before the smoke). I've always acquiesced in the past but might fight a little harder next time. Is this generally accepted? The rules for smoke launchers are on pg. 62, and make not one single mention of passengers. Link to comment Share on other sites More sharing options...
vonny Posted November 17, 2010 Share Posted November 17, 2010 new FAQ for the main rulebook has the answer for us, on page 4, left column "Q: Can any embarked troops shoot out of a vehicle on the turn it has used its smoke launchers? (p66) A: No." Link to comment Share on other sites More sharing options...
Grey Mage Posted November 17, 2010 Share Posted November 17, 2010 This new FAQ is certainly wracking up the kills. Nice find. Link to comment Share on other sites More sharing options...
Isiah Posted November 17, 2010 Share Posted November 17, 2010 Indeed it is -- just checking through it now. Link to comment Share on other sites More sharing options...
Algesan Posted November 20, 2010 Share Posted November 20, 2010 1) No- the rules specificly dissallow passengers firing if the vehicle moved more than 6".2) Yes, the vehicles firepower has nothing to do with the passengers. Edit: For clarity, wether a vehicle fires or not has no bearing on the passenger, they can do different targets, etc- because they are still different units for all purposes. The only time this doesnt work is a specific rules exception- a shaken/stunned vehicle has the effect of not allowing passengers to fire while still on board the vehicle, though they can of course step out and fire as if theyd moved. Wich is one reason I think rhino bunkers with heavy weapons are a horrible idea. Re: Case #1: They cannot fire from the vehicle, but like the crew shaken/stirred result, they can still hop out and shoot. Link to comment Share on other sites More sharing options...
Grey Mage Posted November 21, 2010 Share Posted November 21, 2010 Yes they can, counting as moved. Link to comment Share on other sites More sharing options...
Algesan Posted November 22, 2010 Share Posted November 22, 2010 Yes they can, counting as moved. pg 66 (Fire Points): "Models firing from a vehicle count as moving if the vehicle moves, and may not fire at all if the vehicle moved at Cruising speed that turn." No, they can't unless they disembark. Link to comment Share on other sites More sharing options...
thade Posted November 22, 2010 Share Posted November 22, 2010 Yes they can, counting as moved. pg 66 (Fire Points): "Models firing from a vehicle count as moving if the vehicle moves, and may not fire at all if the vehicle moved at Cruising speed that turn." No, they can't unless they disembark. Algesan, I'm pretty sure GM was responding to the post immediately above his own, i.e. saying they can fire, counting as move, after having disembarked. Link to comment Share on other sites More sharing options...
Grey Mage Posted November 22, 2010 Share Posted November 22, 2010 Yes they can, counting as moved. pg 66 (Fire Points): "Models firing from a vehicle count as moving if the vehicle moves, and may not fire at all if the vehicle moved at Cruising speed that turn." No, they can't unless they disembark. Algesan, I'm pretty sure GM was responding to the post immediately above his own, i.e. saying they can fire, counting as move, after having disembarked. That would be the case. Link to comment Share on other sites More sharing options...
