Token Posted November 18, 2010 Share Posted November 18, 2010 Can obel scouts arrive from a table edge, even if that whole table edge is filled with guardsmen? What if the imps sand 3" from the edge? Link to comment https://bolterandchainsword.com/topic/215342-can-obel-scouts-obel-anywhere/ Share on other sites More sharing options...
wulfric_1066 Posted November 18, 2010 Share Posted November 18, 2010 Can obel scouts arrive from a table edge, even if that whole table edge is filled with guardsmen? What if the imps sand 3" from the edge? If there's a gap large enough for them to fit into with a 1" gap between themselves and the enemy. So a 3" wide space between two units would allow you to fit a scout in. And if they're 3" from the board edge, you can squeeze 2 scouts into the depth. (2@ 1", plus a 1" gap to the IG) Link to comment https://bolterandchainsword.com/topic/215342-can-obel-scouts-obel-anywhere/#findComment-2565765 Share on other sites More sharing options...
Token Posted November 18, 2010 Author Share Posted November 18, 2010 thanks. Link to comment https://bolterandchainsword.com/topic/215342-can-obel-scouts-obel-anywhere/#findComment-2565778 Share on other sites More sharing options...
