MagneticFreak Posted November 18, 2010 Share Posted November 18, 2010 Hello all, Assume that I chose to keep a Tactical Squad and its dedicated rhino in reserve. Is the rhino and the squad a single reserve unit (thus rolling once on the reserve table) or two different units (rolling 2 times, and one could arrive after the other). This sounds silly, but one may want to deploy both separately and roll 2 dice (for instance to use the rhino for some other squad and thus not waste the disambarcation and keep the ability for the infantry unit to charge) Thanks ! Link to comment Share on other sites More sharing options...
Acebaur Posted November 18, 2010 Share Posted November 18, 2010 It can be either a single unit arriving together or two separate units that you roll for together, but you must declare which it is when you hold it in reserve, ie: the beginning of the game. Pg 94 describes this in the left hand side Link to comment Share on other sites More sharing options...
Frosty the Pyro Posted November 18, 2010 Share Posted November 18, 2010 Acebar is correct. When you put something into reserve you decide how it will enter play, including if it is embarked or has any Independent characters attached. Attached Independent characters and embarked units all count as one entity for the purpose of reserves. Any decision made when a unit goes into reserves (including if the unit will deepstrike or outflank) cannot be changed later. Link to comment Share on other sites More sharing options...
