tahrikmili Posted November 18, 2010 Share Posted November 18, 2010 (edited) The Codex states when taking Terminator armor, the Captain loses Power Armor, Bolt Pistol, Chainsword, frag and krag grenades with Terminator Armor, Storm Bolter and Power Sword. Now then, since I don't replace the Iron Halo, do I now effectively have a 2+/4++ save? Edited November 18, 2010 by tahrikmili Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/ Share on other sites More sharing options...
Iron Father Rik Posted November 18, 2010 Share Posted November 18, 2010 No, you don't effectively have a 2+/4+ save, you do have a 2+/4+ save. Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566017 Share on other sites More sharing options...
Myxx Posted November 19, 2010 Share Posted November 19, 2010 Iron Father Rik said: No, you don't effectively have a 2+/4+ save, you do have a 2+/4+ save. Yup. Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566073 Share on other sites More sharing options...
Grey Mage Posted November 19, 2010 Share Posted November 19, 2010 Yep, its one of the complaints about the balance issues in C:SM- you get the same save with artificer armor as TDA. BAs obviously dont have this problem, wich is its own issue. But in either case you keep the halo. Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566174 Share on other sites More sharing options...
tahrikmili Posted November 19, 2010 Author Share Posted November 19, 2010 Grey Mage said: Yep, its one of the complaints about the balance issues in C:SM- you get the same save with artificer armor as TDA. BAs obviously dont have this problem, wich is its own issue. But in either case you keep the halo. Er.. because BA can't take Artificer Armor at all? :) Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566306 Share on other sites More sharing options...
Hellios Posted November 19, 2010 Share Posted November 19, 2010 Grey Mage said: Yep, its one of the complaints about the balance issues in C:SM- you get the same save with artificer armor as TDA. BAs obviously dont have this problem, wich is its own issue. But in either case you keep the halo. Its been so long since I've used the normal dex... but do you get weapons with TDA? because if so they are both pretty expensive but both has pros and cons... TDA might work out a bit cheaper if you get weapons with it but you can't sweep, different weapon options, can't go in rhinos... take up 2 slots in transports and so on, although you do get benefits such as deepstrike... Artificer then allows you to swop the pros and cons around... I still don't get why BA have no AA... seriously... I thought all they did was make pretty armour and stick glitter onto their faces... Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566311 Share on other sites More sharing options...
ShinyRhino Posted November 19, 2010 Share Posted November 19, 2010 Hellios said: Its been so long since I've used the normal dex... but do you get weapons with TDA? because if so they are both pretty expensive but both has pros and cons... You get storm bolter and power sword. The cost of those upgrades to a PA Captain, plus the cost of artificer armor, are relatively close to the total cost of the TDA package. The extra points can be justified in the Relentless ability, as well as the ability to Deepstrike. Just depends on where you need your Captain to be. Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566401 Share on other sites More sharing options...
shatter Posted November 19, 2010 Share Posted November 19, 2010 Hellios said: I still don't get why BA have no AA... seriously... I thought all they did was make pretty armour and stick glitter onto their faces... Reminds me of a 'joke' I heard of an Australian on the idiot box. "You can't polish a turd, but you can roll it in glitter." Yes, at first scan I misread Quote faces... Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566404 Share on other sites More sharing options...
thade Posted November 19, 2010 Share Posted November 19, 2010 Lack of AA armor is fine, we have FNP. I accept, though I miss it. Terminator armor is awesome and has the same saves for the captain...but restricts his transport choices, which is a fair if weird balance to having a 2+/4++ with FNP and Furious Charge, not to mention the chance of being Fearless as well. Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2566632 Share on other sites More sharing options...
Frosty the Pyro Posted November 22, 2010 Share Posted November 22, 2010 ShinyRhino said: Hellios said: Its been so long since I've used the normal dex... but do you get weapons with TDA? because if so they are both pretty expensive but both has pros and cons... You get storm bolter and power sword. The cost of those upgrades to a PA Captain, plus the cost of artificer armor, are relatively close to the total cost of the TDA package. The extra points can be justified in the Relentless ability, as well as the ability to Deepstrike. Just depends on where you need your Captain to be. Relentless is only of marginal use, as storm bolters are assault weapons anyway, so unless you purchas a combi weapon it wont help. Deep strike is fun though. Though I did make a custom rules captain that had terminator armor and a plasma canon. Link to comment https://bolterandchainsword.com/topic/215364-captain-in-terminator-armor/#findComment-2568666 Share on other sites More sharing options...
