zedarkangel Posted November 21, 2010 Share Posted November 21, 2010 Hi, ive recently made these drop pods from templates i found on the web, and i just wanted to show how good something this cheap can be. Although they are tricky to make, its still good if your in need of a cheap drop pod to add to your army. http://i1223.photobucket.com/albums/dd507/zedarkangel/21112010436.jpg http://i1223.photobucket.com/albums/dd507/zedarkangel/IMG_3813.jpg Im planning on painting it, but im afraid that the paint will warp the paper. Anyone have any ideas to avoid this? Link to comment Share on other sites More sharing options...
Cpt. Salvatore Posted November 21, 2010 Share Posted November 21, 2010 I am very interested, what sort of paper you use on these things and how do you glue it together? Link to comment Share on other sites More sharing options...
zedarkangel Posted November 21, 2010 Author Share Posted November 21, 2010 I am very interested, what sort of paper you use on these things and how do you glue it together? Its just thick paper/thin card for most of it, and all you do is cut out the templates, and use either PVA glue or super glue. Super glue is much faster, easier for some bits, harder for others, but better i think Link to comment Share on other sites More sharing options...
Cpt. Salvatore Posted November 21, 2010 Share Posted November 21, 2010 I see. I have a templates I want to try out and I am afraid that the thin card might be too fragile. How it works out, is it hard enough. Also, I forgot, good job on the Pod, it looks really awesome. I was doing one about two weeks ago (GW one) so I can see how cool it is made pretty much. Link to comment Share on other sites More sharing options...
zedarkangel Posted November 21, 2010 Author Share Posted November 21, 2010 I see. I have a templates I want to try out and I am afraid that the thin card might be too fragile. How it works out, is it hard enough. Also, I forgot, good job on the Pod, it looks really awesome. I was doing one about two weeks ago (GW one) so I can see how cool it is made pretty much. Thanks :ph34r: . For your templates, the thin card you have should be strong enough as long as you are using good glue, and that your not making a titan (which there are heaps of templates for) Link to comment Share on other sites More sharing options...
Cpt. Salvatore Posted November 21, 2010 Share Posted November 21, 2010 I am going to make a titan:D Now what?:ph34r: Just a warhound though. Link to comment Share on other sites More sharing options...
zedarkangel Posted November 21, 2010 Author Share Posted November 21, 2010 I am going to make a titan:D Now what?:lol: Just a warhound though. Lol, "just" a warhound? Thats a bit of an understatement :ph34r: Good luck though, what templates are you using? Link to comment Share on other sites More sharing options...
Cpt. Salvatore Posted November 21, 2010 Share Posted November 21, 2010 I am going to make a titan:D Now what?:lol: Just a warhound though. Lol, "just" a warhound? Thats a bit of an understatement :ph34r: Good luck though, what templates are you using? Â So, is that cardboard (corn flakes box cardborad) going to make it? And I am not sure what kind it is, some spain guy:D Link to comment Share on other sites More sharing options...
zedarkangel Posted November 21, 2010 Author Share Posted November 21, 2010 I am going to make a titan:D Now what?:D Just a warhound though. Lol, "just" a warhound? Thats a bit of an understatement :) Good luck though, what templates are you using? Â So, is that cardboard (corn flakes box cardborad) going to make it? And I am not sure what kind it is, some spain guy:D Yeah, cereal box card board should be strong enough, but if your making a titan, you will need alot of it. Good luck Link to comment Share on other sites More sharing options...
MagicMan Posted November 21, 2010 Share Posted November 21, 2010 Pretty sweet droppod dude. Â Â Â If you're worried about it warping, why not stick two bits of the cardboard together (random offcuts) and paint that? Â See what happens. Link to comment Share on other sites More sharing options...
Zeller Posted November 21, 2010 Share Posted November 21, 2010 I think with the paper models you're supposed to coat it in some kind of resin or bondo material to give it a hard outter shell. Though, that may only be for moulding... Link to comment Share on other sites More sharing options...
Asmodeus' Swordhand Posted November 21, 2010 Share Posted November 21, 2010 I gessoed mine to keep them from warping.. works good so long as you keep it really thin and apply it w/o visible brushstrokes. A few coats of primer probably wouldn't even wreck it though. They are a lot more durable than I had always expected. :cuss Link to comment Share on other sites More sharing options...
zedarkangel Posted November 22, 2010 Author Share Posted November 22, 2010 Pretty sweet droppod dude.   If you're worried about it warping, why not stick two bits of the cardboard together (random offcuts) and paint that?  See what happens. :P, thanks. And yeah, good idea, ill try that Link to comment Share on other sites More sharing options...
Obliterator Posted November 22, 2010 Share Posted November 22, 2010 Very nice work! :D Im planning on painting it, but im afraid that the paint will warp the paper. Anyone have any ideas to avoid this? I'd try to give it a coat of gloss varnish first (from an artist store, the stuff they use to seal chalk/charcoal drawings). Once that is dry, just use your regular paints/techniques to paint it up so it matches the rest of your army. I haven't tried this on any paper models though (I usually just slap some paint on there, and make sure I reinforced the paper to prevent warping), so you might want to try it on some spare paper first. Link to comment Share on other sites More sharing options...
zedarkangel Posted November 22, 2010 Author Share Posted November 22, 2010 Very nice work! :DIm planning on painting it, but im afraid that the paint will warp the paper. Anyone have any ideas to avoid this? I'd try to give it a coat of gloss varnish first (from an artist store, the stuff they use to seal chalk/charcoal drawings). Once that is dry, just use your regular paints/techniques to paint it up so it matches the rest of your army. I haven't tried this on any paper models though (I usually just slap some paint on there, and make sure I reinforced the paper to prevent warping), so you might want to try it on some spare paper first. Oh yeah, that reminds me of stuff like hairspray. I used to use that for pastel drawings, so seal it, and it did not affect the paper at all. THanks ;) Link to comment Share on other sites More sharing options...
