MagicMan Posted November 21, 2010 Share Posted November 21, 2010 Hey, im wanting to paint some Aquila's onto my space marines parchment/banner areas, but i can't find a good guide. Can anyone help, or show me their technique? Thanks. Link to comment https://bolterandchainsword.com/topic/215535-painting-aquilas/ Share on other sites More sharing options...
winterdyne Posted November 22, 2010 Share Posted November 22, 2010 Quick photoshop job: http://www.winterdyne.co.uk/maz/images/aquila_example.jpg Use thinned brown/black mix - straight black can be too harsh. Have very little on your brush - you're not doing a wash, but you want your strokes to be translucent. Build up the lines with several passes. You can always sharpen up later with your base colour if you want. 1: Draw an inverted cross at the centre of where you want the aquila to be. 2: Bulk it out to be a triangle above the cross line. Add 2 short diagonal lines to the bottom - these will be the tail feathers. 3: Add the heads - these are basically short 7's with a thick top. 4: Add two small x's connected to the bottom corners of the triangle. These are the claws. 5: Mark the curves of the inner wing - they go from under the neck to above the apex of the 7s forming the head. 6: Add straight lines onto the curves to be the upper and inner feathers. 7: Add feathers starting from either side, and work both sides simultaneously, this helps keep the spacing even on both sides. 8: Add the remaining feathers and extend the tail feathers a bit so they look good. Hope this helps. Link to comment https://bolterandchainsword.com/topic/215535-painting-aquilas/#findComment-2569206 Share on other sites More sharing options...
MagicMan Posted November 23, 2010 Author Share Posted November 23, 2010 Thanks alot! I'll give it a go and try and get a picture of the results. :) Link to comment https://bolterandchainsword.com/topic/215535-painting-aquilas/#findComment-2569772 Share on other sites More sharing options...
Tanhausen Posted November 23, 2010 Share Posted November 23, 2010 That is one sweet tutorial! You make it look so simple... Link to comment https://bolterandchainsword.com/topic/215535-painting-aquilas/#findComment-2569785 Share on other sites More sharing options...
MagicMan Posted November 23, 2010 Author Share Posted November 23, 2010 Ive given it a go, and while not perfect, it certainly looks like an aquila! Thanks for the brilliant guide. Ill try and upload a picture of my efforts tonight. Link to comment https://bolterandchainsword.com/topic/215535-painting-aquilas/#findComment-2569910 Share on other sites More sharing options...
