Quixus Posted November 22, 2010 Share Posted November 22, 2010 Basically what the title says. What would you use to kitbash a Sanguinary Priest in Terminator Armor? If I read the rules right all you need would be TDA, Power weapon and some kind of chalice to follow WYSIWYG, I would think the surgical tool hand from the PA priests/Apothecaries should be there as well. Has anyone done one already? Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/ Share on other sites More sharing options...
Tanhausen Posted November 22, 2010 Share Posted November 22, 2010 I'd say the easiest way out would be taking an AoBR terminator (sarge?), carving out the SB and doing some simple greenstuff of a bowl on top of the fist. You might need to cut and turn the first but not sure. Hope it helps! Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2568839 Share on other sites More sharing options...
Hellios Posted November 22, 2010 Share Posted November 22, 2010 I would use bits from Space Hulk... Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2568979 Share on other sites More sharing options...
Dhx711 Posted November 22, 2010 Share Posted November 22, 2010 Technicly, you don't even need a chalice as the 'dex states that each narcethium contains a shard from a shattered chalice. Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2568988 Share on other sites More sharing options...
Quixus Posted November 22, 2010 Author Share Posted November 22, 2010 The weird thing though is that the priests don't get a narthecium or other medkit according to the army list. Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2568991 Share on other sites More sharing options...
Dhx711 Posted November 22, 2010 Share Posted November 22, 2010 The weird thing though is that the priests don't get a narthecium or other medkit according to the army list. I'm assuming with it no longer having any in-game benefit, it's not listed in the Priest's wargear. Fluff-wise they do have them since SP's are the BA's apothecaries. EDIT: If you want a Chalice I think the only ones in GW's stuff is either from the new Space Hulk game or kitbashing Corbulo Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2569002 Share on other sites More sharing options...
Montuhotep Posted November 22, 2010 Share Posted November 22, 2010 I've seen a very effective conversion of the Terminator Chaplain model - what you would use for the chalice, however, I have no idea at all. Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2569158 Share on other sites More sharing options...
Hemal Posted November 23, 2010 Share Posted November 23, 2010 There is also the Von Carstein vampire Isabella who is holding a chalice, and you could even go as far as modelling a tiny chalice from components from pens and other bits Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2570060 Share on other sites More sharing options...
Quixus Posted November 23, 2010 Author Share Posted November 23, 2010 BTW where does the Prime Helix go on TDA? Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2570070 Share on other sites More sharing options...
Lednera Posted November 24, 2010 Share Posted November 24, 2010 I would say looking at old Ultramarine 2E codex and they had stuff on TDA Apothecaries. It looked like the Helix went in front of the chapter symbol or below or in the center of the chapter symbol. Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2570624 Share on other sites More sharing options...
Brooke Posted November 24, 2010 Share Posted November 24, 2010 I was looking on eBay for some bits earlier and noticed this http://cgi.ebay.co.uk/Blood-Angels-Sanguin...=item4aa67ecebc Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2571109 Share on other sites More sharing options...
Leonaides Posted November 24, 2010 Share Posted November 24, 2010 Or have a look for brettonain grail knight heads - there was an old style horses head with a good sized grail on top... Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2571339 Share on other sites More sharing options...
kharn_the_betrayer Posted November 28, 2010 Share Posted November 28, 2010 I would say to use a basic chalice shape in green stuff or a bit from the Brettonian Knight range (grail knights). The other option is to make a terminator apothecary using the nethacarium bits from the command squad and putting them on the underside of the powerfist or power weapon arm and the back pack bits on the back of the armor. I know White Dwarf did a conversion like this when the Dark Angel book got released back in 2007. If you can find the issue I would say to look at the picture there. I don't know the issue number but its release issue or one or two after. Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2574001 Share on other sites More sharing options...
KaosRaptor Posted November 28, 2010 Share Posted November 28, 2010 I've seen a very effective conversion of the Terminator Chaplain model - what you would use for the chalice, however, I have no idea at all. I'm assuming you mean this one? http://www.bolterandchainsword.com/index.p...howtopic=200672 Done by our very own Jawaballs. OP, if you want advice on it, I'd probably fling him a message. Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2574691 Share on other sites More sharing options...
Hemal Posted November 29, 2010 Share Posted November 29, 2010 I've found a few more chalices - Bretonnian Grail Knights (older models) banner top is a grail.... Link to comment https://bolterandchainsword.com/topic/215568-sanguinary-priest-in-tda/#findComment-2575321 Share on other sites More sharing options...
