Cracked the Seal
Requiemnex
The only major difficulty with Drop Pods these days is that they grant a Kill Point when destroyed - against certain armies, this is going to put you at a disadvantage, since you will have almost twice as many Kill Points on the table to target as they will.
For objective-based missions, this isn't a problem, obviously.
-Stormshrug
...Drop pod mech is harder then pure drop pod.
If that's true than apparently I've been doing it the hard way for quite some time. Just don't tell those guys I've been beating down lately ;)
Dropmech is actually both quite popular and successful (from what I've seen anyway) When used properly take advantage of both builds without too many of the issues created from specializing in one or the other, i.e.- limits to post-deployment mobility with drop pods lists and limited first turn contact from mech lists.
I use a couple of drop pods and they tend to work well. They can give up easy kill points but you will be playing objective games most of the time anyways (2 of the 3 types) giving you a major advantage since you can land scores of troops on an objective across the table. Hope you enjoy using them and welcome back to the game
