Scibor Celtic Warrior as a Terminator
TheAmbit
Hello,
I'm looking at purchasing some of Scibor's celtic warrior bodies shown here:
http://sciborminiatures.com/en_,shop.php?art=961
I want to use them as terminators to make a couple Space Wolf HQ choices. I'm curious if I attach terminator arms would they look really bad and I'd also like to know what they look like next to a regular marine and terminator for size comparison.
I realize the terminator helmet won't fit on the model and it won't 'look' like a terminator, but I'm curious if the model has enough girth and size to be a suitable standin with terminator arms and shoulders attached.
Any help or pictures especially would be great. Thanks
i use a scibor mini for my counts as calgar (when i'm not using C:BT) and its looks good.
my only problem was the back which i didn't like so i used the AoBR termies i had spare and did this...
size wise its a little bigger than a termie (perfect in my opinion)
hope the helps
SB
Thanks, that helps a ton. The only thing more helpful would be a photo of a comparison of all 3 models (scibor, terminator and marine). If they're slightly larger than a terminator I think they will be perfect. Terminator arms and shoulderpads should fit right on them.
i have taken some camparison pics for you.
the problem is i biggerise my termies with greenstuff in the torso and plasticard under the feet so the termy is a bit taller than normal.
the iron warrior is also biggerised a little bit (just plasticard under his feet)
the champion his is with is the same height as he was, so about commander size.
good luck with your scibor hunt!
SB
