Sandboxxx Posted December 2, 2010 Share Posted December 2, 2010 In regaurd to the Landspeeders, the crew should be part of the 8th company so if you wanted to run 20 speeders (x2 for crew) that would leave you with 60 more spots to fill with other assault oriented marnies. Hope that helps. Link to comment https://bolterandchainsword.com/topic/215860-priory-of-dorn-chapter-organization/page/2/#findComment-2578279 Share on other sites More sharing options...
AngryJohnny Posted December 4, 2010 Author Share Posted December 4, 2010 Thanks again everyone for all the comments and feedback so far. It has all been very helpful. I've made several amendments to the Chapter Organization. I've also created two versions of the chart. I'd like some feedback on which version looks better. The only difference between the two, is there is a background image in one and not the other. Here are the revised organization charts. (I posted them as links because they are quite large.) Priory of Dorn Chapter Organization # 1 Priory of Dorn Chapter Organization # 2 Here is a list of the amendments that I made to the Chapter Organization based the suggestions & feedback I received: Reduced the total number of Land Raiders the Chapter has access to down to 15. Reduced the total number of Veterans in the 1st Company to 50. Reduced the number of Sternguard Veterans in each company to 10. Updated the 8th Company to allow for the Land Speeder pilots. Removed the Sternguard Veterans from the 10th Company. Added Apprentices to the Apothecarion. Added 5 Rhino Transports to the Apothecarion. Added a Damocles Command Rhino to each Company (except the 1st, 8th & 10th). Increased the number of Razorback Transports each Company has (except the 1st, 8th, 9th & 10th) to 4. Updated the 10th Company to allow for the Land Speeder pilots. *NOTE: The number of Devastator Marines in the 9th Company should read 80 not 90. I will make the correction once I decide which version of the Chapter Organization Chart to use. Link to comment https://bolterandchainsword.com/topic/215860-priory-of-dorn-chapter-organization/page/2/#findComment-2580053 Share on other sites More sharing options...
chaplain belisarius Posted December 12, 2010 Share Posted December 12, 2010 looking good...;) Link to comment https://bolterandchainsword.com/topic/215860-priory-of-dorn-chapter-organization/page/2/#findComment-2587464 Share on other sites More sharing options...
