stripping acrylics
Focke
Here it is:
331 replies...
I use Isopropylic Alcohol: reusable and in 2 hours usually removes all of the paint. If very nasty paint work or you want to remove primer, you can keep it in DAYS and no harm to plastic (I've kept it in 1 month because I forgot xD). Just remember to put a lid, to prevent evaporation.
Hope it helps!
Edit: Nail polisher... be POSITIVE its acetone free... or say good bye to your plastic models.
I have just purchased some stuff from Homebase called 3-IN-ONE Heavy duty cleaner degreaser. It is a foam type spray that is meant to remove pain & grease etc from engines so thought it would work on my old models I am trying to strip. Didn't do much as after 5 mins the stuff evaporates and the paint comes off if I scrated it off with my nails. Gonna buy a soft wire brush to see if that helps. If I get any good results I will add to the thread.
