DapperDave Posted December 2, 2010 Share Posted December 2, 2010 (edited) Pretty much everyone knows yellow can be a real pain in the buttress to get right. I had heard of a method using pink as a base coat and decided to try it out in preparation for an Imperial Fists biker army I've been cooking up. Here's my step by step: 1) After priming (i used grey here, white would probably work, but could be brighter? not sure about black... it would probably just take more pink), base coat the areas to be yellow in a nice bright pink. I used a 40/60 mix of warlock purple and skull white, but any bright pink should work. But make sure the pink coat is smooth and solid before proceeding (about 2 or 3 layers) http://plasticspaceguys.com/uploads/ImpFist_scoutbike_step1.jpg 2) Cover the pink with thinned layers of Golden Yellow. Again, this took me about 2 or 3 layers of very thin paint to get to. You should notice the pink showing throw now looks a golden orange. http://plasticspaceguys.com/uploads/ImpFist_scoutbike_step2.jpg 3) Give the whole thing a wash the yellow in gryphonne sepia. http://plasticspaceguys.com/uploads/ImpFist_scoutbike_step3.jpg 4) Soft edge highlight with golden yellow: http://plasticspaceguys.com/uploads/ImpFist_scoutbike_step4.jpg 5) Get the deepest recesses with ogryn flesh wash, add some thin edge/corner highlights with sunburst yellow: http://plasticspaceguys.com/uploads/ImpFist_scoutbike_step5.jpg And voila! It's a very luminous / rich yellow and although there's many layers too it - it's not super complicated to pull off. However there's two things to be aware of. 1) Because there's so many layers here you really need to make sure your paint is thinned. The normal description is of skim milk, I went a little beyond this and it worked out well. 2) Since the color we're making is fairly complex, touch ups are a real pain. Though I did the yellow first here, it would probably make things easier to do the yellow last when painting the mini. And here's the finished product: http://plasticspaceguys.com/uploads/ImpFist_scoutbike_front_right.jpg http://plasticspaceguys.com/uploads/ImpFist_scoutbike_left.jpg http://plasticspaceguys.com/uploads/ImpFist_scoutbike_rear_left.jpg Here's a tac marine with the same technique applied: http://plasticspaceguys.com/uploads/ImpFist_test_front.jpg Hope this proves useful to someone! Edited December 2, 2010 by DapperDave Link to comment https://bolterandchainsword.com/topic/216285-painting-yellow-from-pink/ Share on other sites More sharing options...
Wolf Lord Mjolnir Posted December 2, 2010 Share Posted December 2, 2010 Amazing and very impressive - nearly makes me want to do an Imperial Fist army!! Link to comment https://bolterandchainsword.com/topic/216285-painting-yellow-from-pink/#findComment-2578378 Share on other sites More sharing options...
DapperDave Posted December 2, 2010 Author Share Posted December 2, 2010 And ugh... Didn't see the painting yellow FAQ (I swear I searched for "painting yellow" but it returned pretty much every forum post not about yellow @.@)... this should probably be in there. Sorry, admins. Link to comment https://bolterandchainsword.com/topic/216285-painting-yellow-from-pink/#findComment-2578381 Share on other sites More sharing options...
