Paint mixing
Wouldn't use white as that can create a pastel color. A lighter shades of green to highlight or adding a bit of yellow to lighten can work.
Jade Green is a little more toward the blue side. What chapter scheme are you going for?
I use Vallejo, all their paints mix well together. Can't say for mixing with other brands beyond getting coats of wash.
Remember to shake them well before using and add a couple of drops of flow-aid into the mix.
https://bolterandchainsword.com/topic/216322-paint-mixing/#findComment-2579141
I've been mixing GW and Vellejo paint on several occasions and never ran into any trouble. I think you will be fine.
But yeah do as hkm said, shake very well before use, since I found especially Vallejo colors tend to segregate a lot and fast.
Cheers and good luck
https://bolterandchainsword.com/topic/216322-paint-mixing/#findComment-2579369
