POMS rules check
A Land Raider can fire one more weapon than would normally be permitted. Codex: Space Marines, page 81
Assuming we are discussing C:SM and/or C:BA, PotMS allows a vehicle to fire one more weapon than it otherwise could, but does not say that it allows a weapon to be fired twice, which is explicitly forbidden in the BRB.
There is a significant difference between firing an additional weapon, and firing a weapon an additional time.
To put it in another context- theres a big difference between being able to drive a car twice as far, and being able to make two trips- namely, getting back home.
it says can fire one more than normally permitted. if you can only fire it once witch i know and it does say one more than permitted because it doesnt say apart from the same weapon it is a loop hole however is a legal thing to do.
:P
PotMS states the vehicle can fire one more weapon than would normally be permitted. It does not state the vehicle "can fire a weapon one more time than would normally be permitted." It says the Land Raider can fire one more weapon, not that a weapon can fire once more.
You're being blind to the line that read "subject to normal shooting rules." Stop doing that and the rules work fine.
Otherwise, the LR could be shooting when off the table, in different player turns, phases, across the room and onto another player's game.. blahblahblah... but as the PotMS rule says it's subject to normal shooting rules, it can't do these things, including firing the same weapon twice which is most definitely stated as a no.
Subject to something means the something is the boss. Like an Emperor and His subjects. If you ignore this, you'll lose your head.
