Phlegon Posted December 15, 2010 Share Posted December 15, 2010 Hello, I was wondering if I had a Librarian in a Land Raider can I use his powers such as Null Zone. I have a game against demons tonight and I was thinking how great it would be to have a av 14 reroll invulnerable save riding around. Thanks Link to comment Share on other sites More sharing options...
dswanick Posted December 15, 2010 Share Posted December 15, 2010 Yes, that will work just fine. Q: Can a model use a psychic power that is not a Psychic Shooting Attack if it is embarked in a transport vehicle? (p50)A: Yes. If the power requires line of sight, this is still worked out from the vehicle’s fire points (this will count as one model shooting through that fire point if the power is used in the Shooting phase). If the psychic power does not require line of sight and has a range or an area of effect that is normally measured from the model using it, these are measured from the vehicle’s hull, as explained in the Embarking section on page 66. Link to comment Share on other sites More sharing options...
Dan VK Posted December 15, 2010 Share Posted December 15, 2010 Yes, that will work just fine.Q: Can a model use a psychic power that is not a Psychic Shooting Attack if it is embarked in a transport vehicle? (p50)A: Yes. If the power requires line of sight, this is still worked out from the vehicle’s fire points (this will count as one model shooting through that fire point if the power is used in the Shooting phase). If the psychic power does not require line of sight and has a range or an area of effect that is normally measured from the model using it, these are measured from the vehicle’s hull, as explained in the Embarking section on page 66. :o Link to comment Share on other sites More sharing options...
