Wolf Lord with Wolf Pack and Thunerwolves nearby
The Rose Princes
So you have a Wolf Lord on a Thunderwolf who joined a unit of Fenrisian wolves... they fail the morale check using the Lord's Leadership of 10.
Low and behold, there happens to be a unit of Thunderwolf Cavalry unit nearby, within 12", and with Wolfkin the Fenrisian Wolf Pack is allowed to reroll a failed Morale test. Even if the morale test was rolled off the Lord, since the unit he is attached to is a Fenrisian Wolf Pack, they can still reroll the morale test using the Lord's Leadership 10.
This is correct?
I'm at work and my codex isn't at hand, but wouldn't you get the reroll regardless of twc position if the lord is on a TWM? I am under the impression that TWM's count as well for that. Please correct me if I am wrong.
You are correct on this, the rule states they may re-roll their LD test if theirs a Twolf Cav model within range. The Lord on a Thunderwolf is such one going by logic.
TWC have Wolfkin.
"Any unit of Fenwolves may re-roll any failed morale tests if they are within 12" of a TWC.
TWM has no such rule, just that it can only join TWC or Fenwolves units.
So you need the TWC to give the re-roll to the Fenwolves who are lead by the ThunderLord.
3/36 x 3/36 = 9/1296 or 0.7% chance of failure. Delicious
