Voltaire Posted December 19, 2010 Share Posted December 19, 2010 Page 37 of the warhammer40k rule book: "If a unit other than a vehicle suffers any unsaved wounds from a pinning weapon. It must immediately take a pinning test...." "As long as the tests are passed, a unit may be called upon to take multiple pinning tests in a single turn, but if a unit has already gone to ground, no further pinning tests are taken." So basically a unit of sniper scouts shoots at some orks. The orks take 4 wounds. They take four pinning tests until they are pinned, or pass them all. I don't see where it says anything otherwise so why are people saying it's one pinning test per turn? Link to comment Share on other sites More sharing options...
Legatus Posted December 19, 2010 Share Posted December 19, 2010 It is not one pinning test per turn. It is one pinning test caused per enemy unit. That#s how it has allways been, that's what the text in the rulebook is clumsily trying to convey (doing a horrible job), and thankfully, that's what the recet Rulebook FaQ states as well (page 2, bottom left): "Q: How many Pinning tests can a squad firing multiple Pinning weapons cause on the enemy it is shooting? (p31) A: Each unit can only cause a maximum of one Pinning test on each enemy unit wounded, per turn, regardless of the number of wounds caused, unless specifically stated otherwise." Link to comment Share on other sites More sharing options...
Dan VK Posted December 19, 2010 Share Posted December 19, 2010 Legatus summed it up perfectly. :rolleyes: Link to comment Share on other sites More sharing options...
Grey Mage Posted December 19, 2010 Share Posted December 19, 2010 And thank god, that argument had gotten very old. Its nice to see GW answering questions that will actually help us out. Link to comment Share on other sites More sharing options...
nurglez Posted December 19, 2010 Share Posted December 19, 2010 yes, if only they did it sooner and more often. Link to comment Share on other sites More sharing options...
thade Posted December 20, 2010 Share Posted December 20, 2010 And thank god, that argument had gotten very old. Its nice to see GW answering questions that will actually help us out. It's a nice change. =) Link to comment Share on other sites More sharing options...
Voltaire Posted December 20, 2010 Author Share Posted December 20, 2010 But... but... *dies a little inside* sniper scouts....? We could stop nids Link to comment Share on other sites More sharing options...
Grey Mage Posted December 21, 2010 Share Posted December 21, 2010 But... but... *dies a little inside* sniper scouts....? We could stop nids Yes, and Tau could stunlock everything, all the time, cheaply. Trust me... its better this way. Scouts are still great at ripping appart carnifexii. Link to comment Share on other sites More sharing options...
Phosis Posted December 27, 2010 Share Posted December 27, 2010 carnifexii. That is hurting my brain because I know it's correct. Link to comment Share on other sites More sharing options...
igotsmeakabob!! Posted December 28, 2010 Share Posted December 28, 2010 A tad off-topic: If a unit takes 25% casualties from an ordnance weapon, does it take a pinning AND morale test or just pinning? Link to comment Share on other sites More sharing options...
SeattleDV8 Posted December 28, 2010 Share Posted December 28, 2010 A Pinning test at the end of the Units shooting and a Morale test at the end of the shooting phase. BRB pg.24 Going to Ground. Link to comment Share on other sites More sharing options...
Algesan Posted December 28, 2010 Share Posted December 28, 2010 Page 31 under Pinning: Pinning tests are taken immediately if a unit has an unsaved wound from a Pinning weapon. Page 44 under Taking Morale Checks - A): Morale checks are taken for casualties at the end of the phase when the casualties were taken. So, in that case you would check for Pinning after you pull the 25% that missed their saves and then at the end of the phase you check Morale. If you fail that, then you will lose your Pinned status since you will now be falling back... Link to comment Share on other sites More sharing options...
Seahawk Posted December 30, 2010 Share Posted December 30, 2010 Remember though, it has to be an Ordnance Barrage weapon to cause the pinning test, not just any Ordnance weapon. Link to comment Share on other sites More sharing options...
Algesan Posted December 31, 2010 Share Posted December 31, 2010 Remember though, it has to be an Ordnance Barrage weapon to cause the pinning test, not just any Ordnance weapon. Any Barrage weapon will do, including mortars which use the small blast and aren't Ordnance weapons. Link to comment Share on other sites More sharing options...
Seahawk Posted January 1, 2011 Share Posted January 1, 2011 Mine was in response to this question, so I only needed to talk about Ordnance weapons at that point :P: If a unit takes 25% casualties from an ordnance weapon, does it take a pinning AND morale test or just pinning? Link to comment Share on other sites More sharing options...
