dannygravestones Posted December 23, 2010 Share Posted December 23, 2010 Ok, so if I understand this correctly, template weapons do not roll to hit, so my question is this: What effect does a sgt's signum have on a Devistator with a Plasma cannon? I haven't run into this in a game yet, but it's only a matter of time, and would like to be properly informed. Thanks! Link to comment Share on other sites More sharing options...
greatcrusade08 Posted December 23, 2010 Share Posted December 23, 2010 template weapons dont roll to hit, but they do scatter.. you roll the scatter dice and reduce your BS from the distance.. the signum gives you +1Bs which works to reduce scatter by a further inch Link to comment Share on other sites More sharing options...
Grey Mage Posted December 23, 2010 Share Posted December 23, 2010 Yep- it really is that simple. Since you subtract BS on a rolled arrow from the scatter +1 GS from the signum equals -1 " of deviation. Link to comment Share on other sites More sharing options...
narf Posted December 24, 2010 Share Posted December 24, 2010 dont forget though that as its a plasma weapon roll one d6 separatly and before you roll the scatter dice, if this is a one, then make an armour save, and you dont get to shoot with it that turn. (unless your a vehicle) Link to comment Share on other sites More sharing options...
SeattleDV8 Posted December 24, 2010 Share Posted December 24, 2010 Pendantic alert! Templates use the Teardrop Marker (As per the Flamer) which does not scatter. Blast/Ord weapons use the Blast Marker which does scatter. Other wise the above is correct. Link to comment Share on other sites More sharing options...
