Truescale bases
Regular bases tend to make them more gaming legal as they are the same size as regular marine bases but 40mm do give you more room to play around with.
Personally I give them the regular bases out of fairness to my opponents but am currently making some with some non GW 30mm bases which are halfway between the two.
As far as I can remember, you can go up in size on the base, the only restriction is that the base that you cannot use a base that is smaller then the base supplied with the model. The only problem with using non standard bases can occur when you get into close combat situations.
