Chapter Name
CKO
Thanks for your responses and I think I am going to use all of them! Different sectors will call them different things depending on the deeds of the chapter, but the majority of them will include Predator.
Sort of. Their true name would be known to those they have fought beside, and anything with a colour in it would have to be out unless each time they go to war they repaint their armour, which would be very unorthodox.
Why do you need them to have that many names? In any case it's not really all that relevant to any IA you may write on the chapter. Astartes are collectively and individually known by many different names, but each IA does not have a glossary of the terms used to described each individual chapter.
I'd advise to pick one name and stick with it, build the chapters character before you go into ancillary details like what the massed Imperial populace calls them.
https://bolterandchainsword.com/topic/218027-chapter-name/#findComment-2601056
Do you guys think that something like that will work?
Thanks for your responses I am going to use Predators as the chapter name, but different sectors will call them different things depending on the deeds of the chapter. I think I worded it better the second time, thanks to grey hunter ydalir.
https://bolterandchainsword.com/topic/218027-chapter-name/#findComment-2601061
