Panda_ Posted January 8, 2011 Share Posted January 8, 2011 Hi, I've got a basic question of about the timing of this Psychic power. My sorceror with Lash joined a unit of basic marines. An ennemy unit is 13' from my unit. I target it with mine and lash it. If lash is successful, will I be able to double tap it or not ? Lash's timing: Instead of firing a weapon... Link to comment Share on other sites More sharing options...
Captain Juan Juarez Posted January 8, 2011 Share Posted January 8, 2011 Hi, I've got a basic question of about the timing of this Psychic power. My sorceror with Lash joined a unit of basic marines. An ennemy unit is 13' from my unit. I target it with mine and lash it. If lash is successful, will I be able to double tap it or not ? Lash's timing: Instead of firing a weapon... From what you've said, Lash is used instead of firing a weapon during the shooting phase - so the answer would be no, because you need to Lash them to bring them close enough to shoot in that way, which you cannot do outside the shooting phase. Unless I've misunderstood what you mean; don't have a Codex handy. Link to comment Share on other sites More sharing options...
Seahawk Posted January 8, 2011 Share Posted January 8, 2011 Can't do it. All of a squad's members fire at the same time, so if you want this trick you'll have to get the character more than 2" away from the unit (ie, out of coherency and out of the unit). Link to comment Share on other sites More sharing options...
Panda_ Posted January 10, 2011 Author Share Posted January 10, 2011 Does that mean I can rapid fire a Nob unit and lash it outside of charge range while staying inside the Marine unit ? Link to comment Share on other sites More sharing options...
Grey Mage Posted January 10, 2011 Share Posted January 10, 2011 .... yes. They get lashed as the shooting happens- wich means youve already checked range. Link to comment Share on other sites More sharing options...
