Loganwing on foot
BigJon
How viable is is a Loganwing army on foot? I'm putting together an 1850 point list and am going
for model count with punch but I worry about making it to the other side for objective grabbing.
Right now I have 30 Terminator models in the list with Logan, a Rune Priest and Arjac
as the only characters. Is that enough wounds and saves to make it 6 turns or should
I drop some Terminators and add Drops or Land Raiders?
https://bolterandchainsword.com/topic/219030-loganwing-on-foot/
It depends really. I don't think pure footslogging terminators is strictly competative. I just think it lacks the long range firepower to make armies double take, though you have the right ideas down.
It depends how you have equiped your squads out though, I don't really have a sense of persective on how to help aside from drop Ajack for pods, then drop the termie squad and try make room for missle Long Fangs. That way you can put the full weight of your fire on one flank. I am a bit tired right now though.
I've played against a similar list using my IG. The first time was a killpoints mission. I used 1850pts against 2000pts. I went first after seizing the initiative. I tabled him in 5 turns. The second game was a wacky score a pt every turn if you're on an objective, on a table with a ton of terrain and I went 2nd. He scored max points but we killed about the same in victory pts. Yes, they were using VPs.
Thanks Torin, I had thought of that, but I think if I stick Logan with 10 Wolf Guard with Cyclone ML's and give them tank hunter that s four +1 Missile shots from his squad. I think I would rather keep the Long Fangs for some range support. This is also a foot slogger list, if I was dropping them then
I would consider Logan in pod with Long Fangs and give them all MM's.
That link is to a great thread, might have to bring it back to life at some point :lol:
I tried foot slogging logan wing 1500 points(logan, rune priest, 4x5 terminators and some lone wolves) and I had trouble with it. Walking up the battlefield was a real issue, especially in objective games (especially the 1 objective in each deployment zone one), and dawn of war is annoying too, lost the first few games I played due to lack of speed.
After adding in 3 drop pods in place of the lone wolves I generally do a lot better, though my current list is.
logan
wolf lord twc ss fb
5 termies drop pod
5 termies drop pod
5 termies drop pod
3 twc ss pf
the termy squads have cyclone, ss, pf, combi weps and some wolf claws each, I generally deploy one of the squads for logan to join. The TWC group, while expensive, add some hard hitting and an even more juicy target then my 5man squads :)
I've tried to fit in a landraider or 2 at 1500 points and I just cant make it work.
Already ahead of you Ragnarok, the main point of this thread was to discuss how to run a foot based Logan Wing, I never ment for it
to turn into an army list post. I went ahead and started a list post in the army section. I was hopping for some insight on the best
way to make a Logan Wing foot list work. Its just this topic bleeds between listing and tactics.
