How'd you build your Logan?
Anyone have an opinion on having the stormbolter attached to a power fist arm? I know Logan doesn't have a powerfist, but since he can use his axe like one if he wants to, would modeling a powerfist on him be kosher?
There's really lots of options. The easiest would be to just model a normal hand-held storm bolter - just because the actual Logan sculpt has it wrist-mounted doesn't mean your Logan has to do it that way. Particularly if you're using plastic Wolf Guard terminators, just make sure he's more blinged-out than normal - give him the wolf cape and the wolf pelt loincloth legs to make him stand out.
The Grey Knight character Brother Capt. Stern (metal model) has a wrist mounted storm bolter. So if you don't want to do a conversion type gig, just use him. Maybe even swap out the fancy sword he has for an axe.
If you're building a Logan from plastic parts, then it shouldn't be to much of a problem to cut an axe/sword off of a left hand (leaving a "clenched fist") and put a wrist-mounted storm bolter on the back of the wrist. As for the storm bolter piece, a few things come to mind. See if a dreadnought's storm bolter attachment isn't too large. If it is, you could modify a hand-held storm bolter. Options there could include either cutting off the magazine and handle/trigger, or you could even just cut off the handle and mount it upside down with the magazine pointing upward.
Hope that helps.
this is my renegade chapter master sleipnir, while the claw isn't a brilliant frost weapon stand in, I also wanted a model I could use as Abaddon B)
http://i31.photobucket.com/albums/c397/nurglez/my%20logan%20wing/Sleipnir1.jpghttp://i31.photobucket.com/albums/c397/nurglez/my%20logan%20wing/sleipnirleft.jpg
I'm currently converting Logan Grimnar for my "Loganwing" army. Just like YoungWolf, I'm using a Wolf Guard terminator as the base, with a converted axe. For the head, I'll be using one from the grey hunters box. Nothing too special, but it's already looking better than the GW metal mini.
~fearlessgod~
Ditto. I'm most of the way done with mine now, although the axe does not have any wolves on it and I am still figuring out the stormbolter details.
God I hate that metal Logan. It is so disproportional. He's either suffering from massive osteoporosis or he is a mutant who's head is lower than his shoulder sockets.
I've gone for a FW torso & shoulder pad, WGTerm legs, cloak & storm bolter, to get the maximum amount of wolf icons/tails/heads on to the model. Axe is the shaft from the Chaos Lord Term, head is from a Chaos Warrior with the icons trimmed off and some brass runes stuck on - sure I read that Logan's axe was a reforge chaos weapon, somewhere?
Here's what I came up with so far. Everything is from the SW termie box, except for his head, the top of the axe, and the stormbolter which are from the regular SW box.
http://i1221.photobucket.com/albums/dd464/Madphatcat/Logan1.jpg
Thanks man, this is my first time making my own special character. I'm still trying to decide on my cape options. I am not in love with the wolf pelt cape combo, so I have to figure out what else to do (or just leave it off - maybe he is getting it dry cleaned?).
Luckily (or unluckily?) my other wolf guard in terminator armor are all right now plain jane boring Black Reach terminators, so there would be no confusion if I kept him as is. In this case, my cheapness is a positive. :D
My Arjac has the Chaos Terminator Lord cape. Its mostly "cape", but there is some furryness on the top of it. I suspect you can bits order it cheaply enough.
  • 2 weeks later...
Here's my almost done Logan. If you look closely he is half falling off his base (not glued on yet, base isn't done yet either) and he doesn't have pupils. And I still have to glue on his head. LOL.
http://i1221.photobucket.com/albums/dd464/Madphatcat/Logan1-AColorCorrected.jpg
No pics on hand, but I used the cloaked SW terminator body, the wolf guard head w/ beard & Bionic eye (Grimnar can get wounded too!). Weapon-wise I used the double-headed axe from the Sanguinary Guard (don't worry, i filled the teardrops with green stuff and added a wolf tail), shaved the symbol off a SW terminator power fist and cut & mounted a storm bolter on that arm.
-Huzzah
cool im going to use bjorn northfist as Logan, to get a picture of him (dno how to post them on threads) go on google web and type in Hitech miniatures
then choose 54mm and choose bjorn northfist
I think he is a good model, also there is a thread on another page with him, called big space wolf miniature or something.
