The Bloodied Hunter
Frontline989
I've recently bought the Space Marine Commander box as well as the Space Wolf Accessories Frame with the intention of building a pimped out ornate looking Wolf Lord, more specifically Bran Redmaw.
I know his fluff has him pegged as a MotW carrier however I don't find that option appealing for Independent Characters so I want to give him wargear that makes him reflect his savagery without going MotW. My set up thus far is something close to this. Also since I'd only use him in high point games I'm not much worried about total cost. He's a Lord so he deserves the best wargear.
Bran Redmaw
Power Armor
Plasma Pistol
Frost Axe
Wolf Tail Talisman
Belt of Russ
Meltabombs
edit: good call
Saga of the Warrior Born
https://bolterandchainsword.com/topic/219160-the-bloodied-hunter/
I know it's a quality piece of kit, but I dislike the Plasma Pistol.. Unfortunately there isn't another pistol-sized piece in the armoury - discounting the Bolt Pistol.
I'd say Artificer Armour would be better - I'm Codex-less currently, but I'm almost sure Space Wolves get it?
EDIT:
Bel of Russ
So they can hear him coming? ;)
EDIT:
Bel of Russ
So they can hear him coming? :P
We do but it's called Runic Armor. I would agree if your not worried about cost go with the Runic Armor.
Looked at Runic Armor but it only has an invul save against psychic shooting attacks and I kinda feel like a WL needs an invul save to protect the point investment. I could see storm shielding him but then I'd loose any ranged ability and 1 attack for two close combat weapons. I wanted to get some use out of that 5 BS but its nothing I've set in stone yet.
Keep in mind that it's "against wounds caused by psychic attacks". It doesn't have to be a shooting attack. As long as it's psychic in origin and causes wounds, you get a save.
I dont know if this is the confusion, but you can have Runic Armor and a Belt of Russ, if you have the points that is...
Yes but then the invulnerable save of the runic armor is negated by the belt which has a better 4++. Then the runic armor only gives you a better armor save. So is it worth the points? that question is best answered by the user of said lord.
EDIT: Since both the saga of the bear and warrior born are 35pt make the decision between the two before each game. If you are facing a lot of high strength weaponry then take bear. If you are facing a horde of low strength orks take warrior born and trust your 4++ to save you from anything high strength. Like a power claw.
Starkhan
