Justin2008 Posted January 14, 2011 Share Posted January 14, 2011 Hello everyone, i was thinking earlier today, if you had a IC say a captain in terminator armour in a normal assault squad, and you won combat, and your enemy failed their leadership test. When they are running can you make a sweeping advance, because models in terminator armour are not allowed, but that doesnt stop the assault marines. So would you: A) let them run ;) take the sweeping advance test but using the assault marines leadership (think its that) rather then the captains. :( many thanks Link to comment https://bolterandchainsword.com/topic/219444-sweeping-advance-and-terminators/ Share on other sites More sharing options...
Saphos Posted January 14, 2011 Share Posted January 14, 2011 It is initiative and yes, you would use the Assaultsquads value as the Captain is prevetend from pursuing due to the armour. Link to comment https://bolterandchainsword.com/topic/219444-sweeping-advance-and-terminators/#findComment-2617222 Share on other sites More sharing options...
JamesI Posted January 14, 2011 Share Posted January 14, 2011 If a single member of the squad can not sweeping advance, the squad can not sweeping advance. The terminator captain prevents the squad from advancing. Q: Will one model in a squad that is unable to SweepingAdvance prevent the entire squad from making a Sweeping Advance? (p40) A: Yes. Link to comment https://bolterandchainsword.com/topic/219444-sweeping-advance-and-terminators/#findComment-2617225 Share on other sites More sharing options...
