amrogers3 Posted January 17, 2011 Share Posted January 17, 2011 I am trying to convert a left handed Space Wolves lightning claw into a left handed powerfist. I was wondering if anyone has successfully completely this conversion or if you guys had some pointers? Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/ Share on other sites More sharing options...
Andurin Marvak Posted January 19, 2011 Share Posted January 19, 2011 Honestly, this shouldn't be too hard. Just shave off the blades. Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/#findComment-2624174 Share on other sites More sharing options...
amrogers3 Posted January 19, 2011 Author Share Posted January 19, 2011 Yep, you would think but it looks weird like that. I will throw on some green stuff and "attempt" to sculpt it up. Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/#findComment-2624550 Share on other sites More sharing options...
Andurin Marvak Posted January 19, 2011 Share Posted January 19, 2011 If you have a photograph I could probably help you more. Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/#findComment-2625043 Share on other sites More sharing options...
amrogers3 Posted January 20, 2011 Author Share Posted January 20, 2011 If you have a photograph I could probably help you more.  Yep, here is what I did.  http://i145.photobucket.com/albums/r213/amrogers3/IMG00119-20110119-2108.jpg http://i145.photobucket.com/albums/r213/amrogers3/IMG00118-20110119-2107.jpg  The top is a made out of lightning claw and bottom is a converted PF. Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/#findComment-2625677 Share on other sites More sharing options...
Andurin Marvak Posted January 20, 2011 Share Posted January 20, 2011 That looks fine, like a powerfist normally looks. Did you cut off all the blade/knuckle attachment? Because then that would have looked weird. I meant just get rid of the individual blades, so it would be more like a fist with brass knuckles. Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/#findComment-2625805 Share on other sites More sharing options...
madscuzzy Posted January 20, 2011 Share Posted January 20, 2011 Or a simple alternative is to make 'knuckle dusters' after you shave off the blades. You could add rivets or skulls along the surface to make them leave a mark...:D Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/#findComment-2625825 Share on other sites More sharing options...
amrogers3 Posted January 21, 2011 Author Share Posted January 21, 2011 Thanks for the replies. I am on a GS roll. Now if I can figure out how to sculpt a raised SM collar..... Link to comment https://bolterandchainsword.com/topic/219807-converting-powerfist-from-lightning-claw/#findComment-2627080 Share on other sites More sharing options...
