Brother Captain Kezef Posted January 19, 2011 Share Posted January 19, 2011 What is a Stormraven? Back in 5th edition the Stormraven was a flying APC with big teeth, couldn'r really stand toe-to-toe with enenmy anti-tank units with it's AV12. he 6th edition Stormraven is a very dfferent beast now as the flyer rule provides an added layer of protection since normal shots need 6's to hit a flyer and the jink rule allows it to have a 4+ inv save. This is not to say you can blindly fly into the teeth of a guard lascannon battery and icaraus lascannon/autocannon emplacements will ruin your day (more on that later in the tactica).So we have a complicated beast with the best troop carrying capability in a non-apocalypse game and some very effective anti-tank and anti-tank weaponry. The stormraven has truly become a multi-role gunship in 6th edition and needs some careful planning to use effectively. Weapons So, you have an idea to use a nice, shiny Stormraven. What boomsticks do you want to use in order to suitably chastise the enemies of Humanity? It all comes down to what you want the 'Raven to actualy do. The loadouts allow for 3 broad configurations:1) Anti-Armour2) Anti-Infantry4) Anti-Air5) HybridThe Lascannons are a no-brainer, they are there to put nice shiny holes in the other guy's nice shiny tanks. one shot (with a twin-linked re-roll) at str9 and an AP2. With it's range you can pretty much reach anything on a normal sized board you can see and being on a flying base you can see almost everything. Most flyers in te game are in the AV10/11 range so a str9 lascannon will be putting roles in eemy flyers on 2's and 3's and being AP2 you get +1 on the damag roll which increases the chance of really ruining the enemy aircraft's dayCompare this to the other turret option.The Assault cannons have a much reduced range compared to the lascannons, however the mobility of the 'Raven makes this less of a drawback than it looks on paper. You get 4 Str6 shots with an AP of 4. Sounds like a no-brainer anti-Infantry weapon right? The AC has 2 advantages over the Lascannon when it comes to anti-armour work. First it's rending, any roll of a 6 to penetrate nets you between 1 and 3 additional points of "your armour is toilet paper", I'd advise against factoring Rending into any calculations however, it's useful but unreliable.The second advantage is rate of fire, 4 shots with re-rolls as opposed to one. Against armour 13 or 14 the AC is pretty much useless and even AV12 relies on a rending shot. However many armies rely on AV10 or AV11 mechanised waves and against these armies the AC is king. Examples include ork speedfreak forces, Ravenwing Speeder swarms and Astartes Razorback hordes.Now let us look at the AC in an anti-infantry role. Str6 AP4 will kill MOST infantry with a hit followed by a 2+ assuming they are not in cover. Even against the big boys like 'Nid monsters you are looking at 4+ to wound on most things, there isn't that much out there with a toughness higher than 6. Again rending is useful but can't be relied upon.In the Anti-air role the Assault cannon is really nasty with 4 shots penetrating the average flyer on 4's an 5's and since most flyers have 3 hull points, even the glancing hits can cause serious problems and the AC has 4 shots re-rolling misses.Finaly we have twin-linked Plasma cannons. Plasma weapons are a little hard to use, they lack heavy punch for anti-tank work and do not fire fast enough or have large enough templates to kill infantry. Plasma cannons are marine killers, the small blast is generaly large enough for use on squads with 3+saves and will wound them on an easy 2+. Against the big boys in the 'nid armies some prefer plasma to weapons like the assault cannon as you'll get easier rolls to wound. It all dependson personal choice, I tend not to use plasma but if you go up against allot of power armour (or Eldar aspect warriors, Necrons etc.) then Plasma cannons can be an effective choice for an anti-infantry build. In 6th edition vehicles are no longer immune to gets hot! So be wary, even twinlinked these things have a nasty habit of rolling 1 folloed by 1Bear in mind that plasma cannons are useless against flyers as they can't be hit by blast weapons.For turrets I'd recomend the twin-linked AC's in most cases unless your army lacks any dedicated anti-tank weapons (an example of this is my own SG force which is limited to 6inches when it comes to shooting tanks).Ok, now for the hull. we have 3 options here and it's a slightly more dificult choice.The first option to look at is the humble Heavy Bolter, mainstay of the Astartes with a Str5 same AP as the AC but ony having 3 shots and no rending, it does however have an extended range compared to the AC. While the AC is flexible, the HB is a dedicated anti-infantry weapon and it excells in this role, it can and will destroy most infantry in the open (excpetions, as always, being those annoying 3+ save units). Being twin-linked helps get those shots on target so this weapon can and should be relied upon if your going for an anti-infantry build.In the anti-air role the Heavybolter is less effective as it's only str5, if you want your Stormraven to dogfight it's better to consider other options.The next option is a tad more complicated, the Multi-melta. Outside of range 12 this thing is a poor man's lascannon. Under range 12 however and it almost guarantees a penetrating hit on any vehicle (with a VERY shortlist of exceptions such as the 'Raven's ceramite and the necron living metal monoliths). But this is a potentialy lethal catch, you need to get within charge range of the vehicle in question (and anything the vehicle is carrying). You may be putting your 'Raven at risk from other units defending the target vehicle. I will discuss various tactics for avoiding some of these risks but they can never be completely ignored.6th edition brought another use for the humble multi-melta, it's an AP1 weapon so has a +2 to the roll for penetration and being str8 it's very effective at burning through aircraft armour.The last option is a multi-role and unique in being the only main-weapon on the 'Raven you have to pay for. The Typhoon missle system is essentialy 2 missle launchers. This is an inportant distinction as you are firing 2 shots, not one shot and re-rolling misses like the other weapons. On average you'll nail 2 missles most of the time but there is a chance of missing both. The Typhoon is an expensive compromise, frag missles are not as good as HB shells and Krak missles are not as good as point-blank melta shots and lack the AP value to ignore feel no pain rules.However against swarms of AV10 vehicles the Krak is better than a melta or HB ad against swarms of average/low toughness (gaunts, eldar, guard) units the frag missles are actualy better than a HB. Its a compromise weapon, but not without some distinct advantages to consider.The Krak missles are effective against flyers, while you don't get the re-roll on the miss or the AP1 you get an additional shot which couldmakethe difference.Now we come to the last two weapon systems of the Stormraven, the first are it's 4 one-shot, Bloodstrike missles. These are anti-tank weapons, Str8 is normaly enough to reliably hurt anything that isn't AV13 or 14 (which is most vehicles). The AP means the Bloodstrike ignores FNP and can insta-kill most IC's that are not eternal warrior. The problem with the damn thing is you only get 4 and most games are six turn jobs. It can be a problem figuring out when and how to use them.You can only fire two a turn now so the old tactic of firing them all off from the edge of the board is no longer an option. Blood missles are an awesome anti-air choice with their AP1 and they chew through light vehicles. They are oneshot so can be situational, but very effective if you pick the right targets.Last, but by no means least, is the option to add 2 Hurricane sponsons, this does not come cheap but has it's uses. Defensive fire is gone in 6th ed but weapon destroyed results are random so having another 2 boomsticks to pad your main guns is no small thing. A flyer can shoot 4 weapons a turn so you can have a pretty impressive alpha strike at range 12 or less. Equipment There are three items of equipment you can strap onto a Stormraven.Extra armour used to be essential in 5th edition as it kept you moving and glancing hits where notorious for stopping you from moving. The rules have changed and extra armour is not as essential as it used to be. It's still very useful and if you have the points to spare then strap on the armour plating. But now if it's a choice between extra armou or a plasma pistol I think in more detail than used to.Searchlights are now a bit more useful than they used to be as allot of games will have a turn of nightfighting and the rules have change. It's still not an essential piece of kit but if you have a point spare they may as well be equipped.The locator beacon is an interesting bit of kit, very useful to almost every Space marine army EXCEPT the Blood Angels. Descent of Angels means that we can reliably deploy via jump-pack without needing a beacon. Drop pod armies will normaly have beacons in the first wave of the pods anyway and we tend not to use terminators that much. If your army needs a beacon then put it on but in general it's a waste of points for the Blood Angels. Tactics Now the fun bit!Ok, first and foremost, unless you are packing a squad into the 'Raven, don't take a 'Raven. A predator can do everything a 'Raven can do in regards to firepower and it many ways can do it better. A raven is an assault transport, if your not using it in this fashion you are wasting it's potential! This is true even in 6th edition with the intorduction of flyers, sure the Stormraven is one of the best anti-air units in the game but it also has the single best troop carrying abilities in a non-apocalypse game.Now, what to put into the bloody thing? The best results come from small, elite units that need to get into action quickly. Sanguinary Guard, Death Company, Terminators and vanguard Vets are the prime candidates. The 'Raven is unique in being the only non-apocalypse transport available to the astartes than can carry jump pack troops. To make best use of this versatile aircraft, load a Dreadnought in aswell. A 5 man DC squad with lemartes backed by a DC Dread is a very effective choice.The combination of a 'Raven and a JP squad allows for quick re-deployment (especialy if you have Dante hit and running) a 12 inch move allows the JP squad greater latitude. Just jump to within 2 inches of the 'Raven and load-up. next turn you can either get the hell out of dodge or assault from the 'Raven.I like to run my 'Raven's in pairs, the idea is target saturation. Also remember once they have unleashed their cargo the enemy has a harder choice on targets, allowing the 'raven to act in a gunship roll. Giving the other guy a choice between a JP elite close combat squad, Furioso and 'aven in thier backyardincreases the survival rate of these units as opposed to them being on their own. I tend to use my 'Ravens to deliver troops to target before lurking above them, targeting enemy armour that can cause issues my little inferno pistols can't reach.Finaly we come to dogfighting, the Stormraven is one of the best anti-air weapons in the game as you can unload with 4 AP1 missles, an AP1 multi-melta and an AP2 lascannon. Enemey flyers will rightly fear your Stormraven and you can force them to do nothing much more than jink for half the game while you dominate the skies. Don't be afraid to detach your Stormraven to combat air patrol before/after you deliver it's troop payload.Thankyou for your time. This is not meant to be a comprehensive essay on the use of the 'Raven but instead a primer allowing new players to consider the Stormraven and employ it in their first few games giving them time to appreciate the aircraft and develop their own style and tactics. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/ Share on other sites More sharing options...
JamesI Posted January 19, 2011 Share Posted January 19, 2011 Very nice tactica. Â I have never used a storm raven, but now I'm considering getting one. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624462 Share on other sites More sharing options...
Redo Posted January 19, 2011 Share Posted January 19, 2011 Love your little tactica. Especially the the tactics section and the weapons options. I think it will be very hard to choose which weapons I will go with when the model comes out. I will be getting one for sure...who knows now...perhaps two. Â Just one quick correction. I think you will find that Bloodsrikes missles are S8, AP1 and not ordanance. Still that means that they are rather effective if they even glance and will be rather damaging when they penetrate. Â Thanks for the tactica! Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624473 Share on other sites More sharing options...
Brother Captain Kezef Posted January 19, 2011 Author Share Posted January 19, 2011 Love your little tactica. Especially the the tactics section and the weapons options. I think it will be very hard to choose which weapons I will go with when the model comes out. I will be getting one for sure...who knows now...perhaps two. Just one quick correction. I think you will find that Bloodsrikes missles are S8, AP1 and not ordanance. Still that means that they are rather effective if they even glance and will be rather damaging when they penetrate.  Thanks for the tactica!  oops my bad, we've been doing a campaighn at my gaming group with special ammo rules. Will edit that out. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624478 Share on other sites More sharing options...
Death Spectre Posted January 19, 2011 Share Posted January 19, 2011 The model also seems to come with the option of (twinlinked?) plasma cannons on the turret. What's your take on them? With vehicles ignoring the Gets Hot! rule I've tended to prefer them as a dreadnought-mounted weapon. The str 7 ap 2 blast gives flexibility against monstrous creatures or taking chunks out of hordes. I guess it would depend on what gets played in yuour area, but I like having some tactical flexibility. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624487 Share on other sites More sharing options...
Aetheos Posted January 19, 2011 Share Posted January 19, 2011 Good work on the tactica. Thanks for putting the time in writing it up. I haven't had time to play test the Stormraven yet but with it now up for Pre-Order I'm definitely getting myself 1! Â Just an observation, aren't Hurricane Bolters 3 twin-linked shots, so a pair of sponsons would be a total of 6 twin-linked and not 12? I would assume its the same set up as the LR Crusader. Â Other than a couple of spelling mistakes I think its an awesome summary write up :wallbash:. Thank you. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624488 Share on other sites More sharing options...
Brother Captain Kezef Posted January 19, 2011 Author Share Posted January 19, 2011 Good work on the tactica. Thanks for putting the time in writing it up. I haven't had time to play test the Stormraven yet but with it now up for Pre-Order I'm definitely getting myself 1! Just an observation, aren't Hurricane Bolters 3 twin-linked shots, so a pair of sponsons would be a total of 6 twin-linked and not 12? I would assume its the same set up as the LR Crusader.  Other than a couple of spelling mistakes I think its an awesome summary write up :wallbash:. Thank you.  Bolters are rapid fire, under 12 inches you get 2 shots per bolter.  The model also seems to come with the option of (twinlinked?) plasma cannons on the turret. What's your take on them? With vehicles ignoring the Gets Hot! rule I've tended to prefer them as a dreadnought-mounted weapon. The str 7 ap 2 blast gives flexibility against monstrous creatures or taking chunks out of hordes. I guess it would depend on what gets played in yuour area, but I like having some tactical flexibility.  ARGHHHHHHH!  Completely forgot about those! To the Tactica-mobile! Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624491 Share on other sites More sharing options...
Aetheos Posted January 19, 2011 Share Posted January 19, 2011 Good work on the tactica. Thanks for putting the time in writing it up. I haven't had time to play test the Stormraven yet but with it now up for Pre-Order I'm definitely getting myself 1! Just an observation, aren't Hurricane Bolters 3 twin-linked shots, so a pair of sponsons would be a total of 6 twin-linked and not 12? I would assume its the same set up as the LR Crusader.  Other than a couple of spelling mistakes I think its an awesome summary write up :wallbash:. Thank you.  Bolters are rapid fire, under 12 inches you get 2 shots per bolter.   I forgot about rapid fire ;) LOL Thanks once again mate. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624498 Share on other sites More sharing options...
Brother Captain Kezef Posted January 19, 2011 Author Share Posted January 19, 2011 Added the plasma cannons to the tactica. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624503 Share on other sites More sharing options...
Ebsolom Posted January 19, 2011 Share Posted January 19, 2011 Thanks for taking the time to post this well written and presented tactica, very useful! Â "(with a VERY shortlist of exceptions such as the 'Raven's ceramite and the necron living metal monoliths)" - you can add Wave Serpents to this. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624504 Share on other sites More sharing options...
BLACK BLÅ’ FLY Posted January 19, 2011 Share Posted January 19, 2011 Nice. Â G Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624515 Share on other sites More sharing options...
JamesI Posted January 19, 2011 Share Posted January 19, 2011 This tactica has been added to the Blood Angels resources thread. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624527 Share on other sites More sharing options...
Brother Captain Kezef Posted January 19, 2011 Author Share Posted January 19, 2011 This tactica has been added to the Blood Angels resources thread. Â Cheers mate! I hope it helps new guys get a feel for the Stormraven, it's a great piece of kit and now the model is out it looks great (may needto work on the turret a bit mind). Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624534 Share on other sites More sharing options...
shatter Posted January 19, 2011 Share Posted January 19, 2011 Aww c'mon man... we gots shooty troops too!  Add sternguard into 'serious transport options'. They (and combimelta priest and/or another ic) and a shooty, frag or libby dread aint bad. Even for DS. Most firepower possible on a single reserve roll of all codex astartes forces I think. Heavy flamers on the sternguard as they're assault weapons and can disembark and shoot in a DS move like regular meltas and their combi-meltas.  DS/move 'raven  disembark combi sternies disembark priests (in or out of sternguard 2" range for combi-melta versus more targets) disembark dread.  Shoot stuff. For this I'd prefer the raven to come with the hurricane sponsons and AC. (start with priests) The raven can shoot 2 pieces of armour or 1 armour (potms) and 1 infantry ideally. Each priest can melta shot sternguard can shoot at 1 piece of armour (of 3-8 combi-melta shots) plus HF template overlapping on stuff... but prefer (expensive) infantry. fragdread can shoot melta, frag cannon plus template overlap and magna grapple at one target. Little target preference. Can kill anything.  One reserve roll, up to 5 real and separate attempts to break armour (or a couple more more if you add more priests). If the bad guy has two mere transport vehicles, you'll have a pretty good chance of opening both and having anti-infantry weapons at the ready to blow their cargoes away in the same phase. One reserve roll. Almost anywhere on the table. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624545 Share on other sites More sharing options...
ancient god Posted January 19, 2011 Share Posted January 19, 2011 The Plasmacannon are an option for the turret, so they compete with the Lascannon and Assault Cannon at no additional cost. Â Haven't read further than that but I'll continue to do so now. ;) Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624547 Share on other sites More sharing options...
Brother Captain Kezef Posted January 19, 2011 Author Share Posted January 19, 2011 The Plasmacannon are an option for the turret, so they compete with the Lascannon and Assault Cannon at no additional cost. Haven't read further than that but I'll continue to do so now. :)  That's the problem with being set into a single load out for so long, I forget the others and where they go lol. Pretty much snce I came up with my SG army I've run them with las and melta. Back to the editing suite.  Aww c'mon man... we gots shooty troops too! Add sternguard into 'serious transport options'. They (and combimelta priest and/or another ic) and a shooty, frag or libby dread aint bad. Even for DS. Most firepower possible on a single reserve roll of all codex astartes forces I think. Heavy flamers on the sternguard as they're assault weapons and can disembark and shoot in a DS move like regular meltas and their combi-meltas.  DS/move 'raven  disembark combi sternies disembark priests (in or out of sternguard 2" range for combi-melta versus more targets) disembark dread.  Shoot stuff. For this I'd prefer the raven to come with the hurricane sponsons and AC. (start with priests) The raven can shoot 2 pieces of armour or 1 armour (potms) and 1 infantry ideally. Each priest can melta shot sternguard can shoot at 1 piece of armour (of 3-8 combi-melta shots) plus HF template overlapping on stuff... but prefer (expensive) infantry. fragdread can shoot melta, frag cannon plus template overlap and magna grapple at one target. Little target preference. Can kill anything.  One reserve roll, up to 5 real and separate attempts to break armour (or a couple more more if you add more priests). If the bad guy has two mere transport vehicles, you'll have a pretty good chance of opening both and having anti-infantry weapons at the ready to blow their cargoes away in the same phase. One reserve roll. Almost anywhere on the table.  This is EXACTLY waht i was hoping for when i posted my basic Tactica. The possibilities are endless and the more players who add their own twist to the thread the better :P Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624557 Share on other sites More sharing options...
Demoulius Posted January 19, 2011 Share Posted January 19, 2011 solid tactica overall :) Â have used the raven a few times i can confirm that the extra armour upgrade should moste defenitly be worth it. i havent and it suffered for it :) also your right on the part of its cargo, as soon as it drops them it drops a fair bit on the priority list of your opponent, specialy if its cargo is slaughtering his army :P Â i found the hurricane bolters to be worth their weight in gold. yes its 30 points but the 2 weapons add so many twin-linked shots that those on its own make it a fairly big threat. Â i run mine with the standard heavy bolter and assault cannon and its a fairly powerfull gunboat :) tend to fire the rockets asap as its AV of 12 means its an easy target to down...and well....AP1 weapons at such range are insane :huh: Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624570 Share on other sites More sharing options...
Quixus Posted January 19, 2011 Share Posted January 19, 2011 What do you guys think about this loadout?  Storm Raven (Lascannons, Multimelta, Extra Armor, possibly Hurricane Bolters) Librarian (JP, Shield of Sanguinius, Might of Heroes) Honor Guard (2xThunderhammer, 2xLightning Claw, 4xStorm Shield)  Furioso Dreadnought (2xBlood Talons, Stormbolter&Meltagun, Extra Armor)  or  Dreadnought (Blood Fist, Assault Cannon, Extra Armor, Heavy Flamer)  Weighing in at 815-845 points. Is it good heavy hitter/fire magnet or too many eggs in one basket?  I hope I posted the question in the right place. If not, please detach it. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624615 Share on other sites More sharing options...
Demoulius Posted January 19, 2011 Share Posted January 19, 2011 horrible pointsink m8. if the transport gets taken down (or immobilised) more then half of your army is stranded, which si quite frankly not what you want B) Â such a move is only somewhat affordable in apocalypse imho and even then not recommended. mind you if they got in combat they will take a serious chunk off whatever is on the receiving end :) Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624649 Share on other sites More sharing options...
Code 187 Posted January 19, 2011 Share Posted January 19, 2011 horrible pointsink m8. if the transport gets taken down (or immobilised) more then half of your army is stranded, which si quite frankly not what you want  The SR will probably be public enemy no 1 in the majority of games I would think. Great tactica thanks, gives me plenty to think about :wacko: Your point regarding ACs vs high AV vehicles is something I'd look at though, statistically I think ACs are better than Las:  http://www.bolterandchainsword.com/index.p...howtopic=217832 Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624896 Share on other sites More sharing options...
Till Posted January 19, 2011 Share Posted January 19, 2011 Thanks for the effort Kezef. Â Im gonna grab two and go with typhoon and AS cannons. I run DoA and my biggest weakness is being able to pop a transport, but not having the movement to get it in CC. Its also nice to get dreads in a DoA list. Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624975 Share on other sites More sharing options...
Quixus Posted January 19, 2011 Share Posted January 19, 2011 I run DoA and my biggest weakness is being able to pop a transport, but not having the movement to get it in CC. Its also nice to get dreads in a DoA list.Am I missing something here? The Storm Raven does not get DoA, neither the reserve reroll nor the higher DS accuracy. What's the benefit of either DSing with 2D6 scatter or moving in form the table edge without being able to assault on turn 2 or later, instead of putting the Storm Raven on the table on turn 1? Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2624989 Share on other sites More sharing options...
BLACK BLÅ’ FLY Posted January 19, 2011 Share Posted January 19, 2011 There is not much advantage to deepstriking the Stormraven - no 4+ cover save either. Â G :P Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2625011 Share on other sites More sharing options...
TheMouth Posted January 19, 2011 Share Posted January 19, 2011 I dont get how you can say its not a gunship, "apache" but yet your use of missiles and lascannons really describes it being a gunship, with the option of moving troops. And the comparison against the IG Valks...same armour, worst ballistic skill....how is that a gunship where the raven is not? Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2625014 Share on other sites More sharing options...
Quixus Posted January 19, 2011 Share Posted January 19, 2011 horrible pointsink m8. if the transport gets taken down (or immobilised) more then half of your army is stranded, which si quite frankly not what you want ;)What would you consider the maximum load pointwise for a Stormraven? Link to comment https://bolterandchainsword.com/topic/219950-close-air-support/#findComment-2625038 Share on other sites More sharing options...
