Fred Johnson the 3rd jr Posted January 20, 2011 Share Posted January 20, 2011 All the tutorials I find seem to use more expensive parts, a combi-plasma, combi-melta, a full sized flamer (instead of the BA hand flamer). Is there a tutorial out there for combining a plain old bolter with a Blood Angels hand flamer / pistol flamer thing? Link to comment https://bolterandchainsword.com/topic/220046-combi-flamers/ Share on other sites More sharing options...
Grizzly_bear Posted January 20, 2011 Share Posted January 20, 2011 what i've done is neatly sliced the bolter muzzle off....but keep it to one side then chop off the main bit off of the hand flamer muzzle, glue that on the bolter then add the bolter muzzle above the flamer muzzle..... i'll get a picture up by tonight or tomorrow so you may have a butchers Link to comment https://bolterandchainsword.com/topic/220046-combi-flamers/#findComment-2626138 Share on other sites More sharing options...
averykess Posted January 20, 2011 Share Posted January 20, 2011 I usually use a standard boltgun for combi-flamers and combi-meltas. You can probably see what I did on my sternguard without too much trouble. http://www.bolterandchainsword.com/index.p...howtopic=201742 Link to comment https://bolterandchainsword.com/topic/220046-combi-flamers/#findComment-2626614 Share on other sites More sharing options...
Grizzly_bear Posted January 20, 2011 Share Posted January 20, 2011 I usually use a standard boltgun for combi-flamers and combi-meltas. You can probably see what I did on my sternguard without too much trouble. http://www.bolterandchainsword.com/index.p...howtopic=201742 they're very neat and great looking man Link to comment https://bolterandchainsword.com/topic/220046-combi-flamers/#findComment-2626648 Share on other sites More sharing options...
Fred Johnson the 3rd jr Posted January 20, 2011 Author Share Posted January 20, 2011 I usually use a standard boltgun for combi-flamers and combi-meltas. You can probably see what I did on my sternguard without too much trouble. http://www.bolterandchainsword.com/index.p...howtopic=201742 Hmm, that looks simple to do and good to boot! I may just do that. The BA hand flamers have a smaller flamer bit so it will be even easier to fit on. Link to comment https://bolterandchainsword.com/topic/220046-combi-flamers/#findComment-2626773 Share on other sites More sharing options...
averykess Posted January 21, 2011 Share Posted January 21, 2011 I usually use a standard boltgun for combi-flamers and combi-meltas. You can probably see what I did on my sternguard without too much trouble. http://www.bolterandchainsword.com/index.p...howtopic=201742 Hmm, that looks simple to do and good to boot! I may just do that. The BA hand flamers have a smaller flamer bit so it will be even easier to fit on. I find that if you replace the bolter barrel with one that is as long or slightly longer than the secondary weapon, it makes the weapon look more convincing. Link to comment https://bolterandchainsword.com/topic/220046-combi-flamers/#findComment-2627860 Share on other sites More sharing options...
