Thunderwolf Cav questions ( sorry if redundant)
Captain Talon
I did a quick search, didn't see a topic that looked like it answers me, but....
Legality of of non GW models....is this an issue in any tournaments that you have played at?
It is legal to join an IC on foot with a TWC unit? The unit can only charge 6 inches if he does so...I don't see any other restrictions....
That will depend on each individual tournament and their own rulings. Some will allow third-party (non-GW) models, others won't. You'll have to check with the tournament organizers of any tournament you plan to attend. As a general rule of thumb, any official GW or GW-sponsored tournaments won't allow third-party models, although your own sculpts they will.
Yes, but keep in mind that as TWC are Cavalry, they have both Fleet and the 12" charge. This means should an IC join a TWC unit, if they "Run" they cannot then charge, and should they be able to charge, as you say they can only charge 6".
DV8
Weird, under the upgrades and other equipment it says that "thunderwolf mount" can only join twc and fen wolves, but doesn't mention anything Thunderwolf cavalry...
So by my logic, and unless its been faqed, you can join an IC to twc, but not an IC on twc to a normal squad.
Correct. Thunderwolves are too vicious to add to non-canid units. Independent characters eiding on Thunder Mounts may only join Thunderwolf Cavalry and Fenrisian Wolves and it should be possibly to join with an Iron Priest on Thunderwolf mount too.
