The Emperor's Paladins
What sort of character will they have? Will they retain the Humanitarian aspects of the Sallies? If not, why not?
Yes...Would this go in the Beliefs section?
Yup, also it can tie in to other aspects so might feature elsewhere.
What about interactions with other Imperial organisations?
Hmm, such as the inquisition? and the like
Inquisition, Eccleisiarchy, AdMech, Imperial Guard, Imperial Navy... All the major ones - obviously, you don't have to talk about them unless there is something significant.
Also, I don't recall it being mentioned but it should have been, read the Guide To DIYing and the Octaguide.
Just to clear up the Salamander issue. The Salamanders have no known Second Founding chapters. Basically, after the Horus Heresy they were too beat up to split (a mix of Ivstaan and a bodged warp jump). Since then, they would have returned to normal size (they are slightly smaller but not by much) and would have had successor chapters. So, in short, Salamander successors are okay.
Ok thanks <_<
I've read the Guide to DIYing, not the second one tho.
Could poss. use how admech might not completely trust them because of the armour thing
Just to correct this statement. There is no (known) 2nd Founding successor of Salamanders and whether there was/is successor(s) in subsequent Foundings is matter of much debate amongst the imperial scholars.
Ah, this is a problem. I did do a search to if any chapters had the name "Imperial Paladins" but nothing came up, so i assumed it would be o.k. to have the name.
I'll change the name to "The Emperor's Paladins"
Quick question, i'm trying to flesh out "The battle for Banzen", Banzen is a planet in the home system, and i was just wondering how long (Approximately) an Ork Waaaaaagh would take to wipe out a space marine chapter?
Also if the Waaaaaaagh was this big would other forces be present (E.g. IG, other space marine chapters)?
