plasticard/styrene rods
XKhalilX
Just a tip if you're interested in freebies: a Q-tip w/o the swabs is an excellent size for spears/poles/etc. for units in Terminator armor, and reasonably sized for units wearing power armor. It's durable, reacts to plastic glue, and the inside is hollow, which makes pinning a snap. Pull out a few of those bad boys, clean your ears (to reduce waste ;)) and snap off the swab ends with scissors.
Voila. Cheapy staff rods.
I use 3/64 brass rod for most projects, including banner poles. You may want the next size up for a more beefy look, but you'll have to drill through most of the hand on a normal marine. I definitely recommend using brass rod over plastic rod. Plastic will bend and break very easily, but brass rod is there to stay. An example of the 3/64 used as halberd hafts is below:
http://i178.photobucket.com/albums/w248/Cabal615/003-4.jpg
