Phlegon Posted January 27, 2011 Share Posted January 27, 2011 So I just got a tech marine and I want to magnetize his servo harness so I can swap it out with a conversion beamer. I am having trouble getting the servo harness to stay put and I am wondering, is the servo harness to heavy for my magnets. I have these magnets Some help would be greatly appreciated as this little kink is really holding me back. Thanks Link to comment https://bolterandchainsword.com/topic/220771-techmarine-and-servo-harness/ Share on other sites More sharing options...
Br0ther Rafen Posted January 27, 2011 Share Posted January 27, 2011 i don't use magnets, but maybe you could use two small ones insted of a single? Aside from that, you could always use superglue and then snap the harness off, but that might damage paint and such (done it myself in the past actually). Hope this helps Link to comment https://bolterandchainsword.com/topic/220771-techmarine-and-servo-harness/#findComment-2636862 Share on other sites More sharing options...
rusty1109 Posted January 28, 2011 Share Posted January 28, 2011 The harnes is almost certainly too heavy for magnets alone! But if you put a magnet in the dead centre of his back and a complimentary one on the harness, then surround that with four pins it should hold just fine! Just make sure the pins are glued to the harness so all you have is some small holes on your techmarine. Link to comment https://bolterandchainsword.com/topic/220771-techmarine-and-servo-harness/#findComment-2637027 Share on other sites More sharing options...
Phlegon Posted January 28, 2011 Author Share Posted January 28, 2011 Thanks for your responses but I lucked up and got it to stick with after placing three magnets in a triangle. Thanks Link to comment https://bolterandchainsword.com/topic/220771-techmarine-and-servo-harness/#findComment-2637151 Share on other sites More sharing options...
Bannus Posted January 28, 2011 Share Posted January 28, 2011 I magnetized the servo-harness for one of my Techmarines. I used a rather large magnet (not sure of the size) on both the model and the harness and then built up a greenstuff square "peg" above it (over two metal pins) that helps hold it in place and keep it from spinning. It works well. Link to comment https://bolterandchainsword.com/topic/220771-techmarine-and-servo-harness/#findComment-2637961 Share on other sites More sharing options...
