Warpchild Posted February 1, 2011 Share Posted February 1, 2011 Hey, I have a question and thanks for the answers! Is that correct that three rune priests are ok if they had ONLY ONE different psychic? Example: 1st priest: M. Hurricane, Lightning 2nd priest: M. Hurricane, Thunderclap 3rd priest: M. Hurricane, Jaws All in powerarmour for example but nothing else. Are they ok like that? Or I got to add Meltabombs to one and a combi-melta for the other? Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/ Share on other sites More sharing options...
Decoy Posted February 1, 2011 Share Posted February 1, 2011 You're good that way. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642366 Share on other sites More sharing options...
Coverfire Posted February 1, 2011 Share Posted February 1, 2011 I believe you have to make sure that their Wargear is different too. So Meltabomb on one, Chooser of the Slain on another, and a single bare bones. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642371 Share on other sites More sharing options...
stinkenheim Posted February 1, 2011 Share Posted February 1, 2011 Yeah powers wise you are fine but wargear wise you still need to have differences. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642380 Share on other sites More sharing options...
Grey Mage Posted February 1, 2011 Share Posted February 1, 2011 Yep... give one runic armor and the other a meltabomb... and then youll be ok. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642389 Share on other sites More sharing options...
thor1234 Posted February 1, 2011 Share Posted February 1, 2011 Yep... give one runic armor and the other a meltabomb... and then youll be ok. Why Runic Armour? seems a bit pricey just to blend with the Unique rules..... I'd suggest taking something like Chooser on one and not the other (if want a Chooser on both then just take the other a meltabomb as Greymage suggests) Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642392 Share on other sites More sharing options...
the jeske Posted February 1, 2011 Share Posted February 1, 2011 raven/raven+meltabomb/no raven . but I dont think you need 3 RP unless its 2500 or more. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642610 Share on other sites More sharing options...
Lord Ragnarok Posted February 1, 2011 Share Posted February 1, 2011 If you are stingy for points you can do a melta bomb on one and bolter on another, or a Wolf Tail Talisman on one and a bolter on another. You will have to only spend 5 pts on uniqueness. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642699 Share on other sites More sharing options...
Grey Mage Posted February 1, 2011 Share Posted February 1, 2011 Yep... give one runic armor and the other a meltabomb... and then youll be ok. Why Runic Armour? seems a bit pricey just to blend with the Unique rules..... I'd suggest taking something like Chooser on one and not the other (if want a Chooser on both then just take the other a meltabomb as Greymage suggests) Frankly, as fragile as he is, if Im sending him anywhere near the frontlines I prefer to have runic armor on my Rune Priest. If your fielding 3 of them in a force one of them should probly be on the attack, at the least. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642750 Share on other sites More sharing options...
Daddywarcrimes Posted February 1, 2011 Share Posted February 1, 2011 Find the points to give each one a talisman, unless he's in runic or terminator armor. It's all he gets against Perils of the Warp, but it's better than nothing. It also gives a unit he's joined with a second chance against things like Lash, Paroxysm, Fear the Darkness, and the always deadly Weaken Resolve. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642786 Share on other sites More sharing options...
thor1234 Posted February 1, 2011 Share Posted February 1, 2011 Yep... give one runic armor and the other a meltabomb... and then youll be ok. Why Runic Armour? seems a bit pricey just to blend with the Unique rules..... I'd suggest taking something like Chooser on one and not the other (if want a Chooser on both then just take the other a meltabomb as Greymage suggests) Frankly, as fragile as he is, if Im sending him anywhere near the frontlines I prefer to have runic armor on my Rune Priest. If your fielding 3 of them in a force one of them should probly be on the attack, at the least. I'll have to try that one brother! Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2642994 Share on other sites More sharing options...
Sarapham Posted February 1, 2011 Share Posted February 1, 2011 Find the points to give each one a talisman, unless he's in runic or terminator armor. It's all he gets against Perils of the Warp, but it's better than nothing. It also gives a unit he's joined with a second chance against things like Lash, Paroxysm, Fear the Darkness, and the always deadly Weaken Resolve. The talisman does not work against Perils of the Warp since that is not a psychic attack/effect. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2643002 Share on other sites More sharing options...
Warpchild Posted February 1, 2011 Author Share Posted February 1, 2011 Thank You for the answers! I`m building wolfwing "1500 pts in the lunchbox" army and I wanted loads of psychic. I`m totally new to the footslogging TDA, I used to play orks, DE and bit of SM/CSM. Have ten points to spare, so I`ll go with a meltabombs and convert a combi-weapon and the third will have nothing (that`s different, isn`t it?). Is the Living lightning any good for anti-tank on the table? Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2643022 Share on other sites More sharing options...
stinkenheim Posted February 1, 2011 Share Posted February 1, 2011 Yep, the way you would have equipped them would now cover the rules. Living lightning can be ok, mostly against light walkers (sentinels and killer kans) as well as transports like rhinos. Armour 10-11 is really the only thing you should reliably use it against. At a push armour 12 but any higher than that and the target should be engaged with missile launchers etc. unless you have shot everything and need it taken down. Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2643027 Share on other sites More sharing options...
Fred Johnson the 3rd jr Posted February 2, 2011 Share Posted February 2, 2011 Just to be clear, and maybe to beat a dead horse, HQs: Cannot have identical wargear (guns, armor, close combat weapons, grenades, chooser of the slain, wolves etc; ) Cannot have an identical set of psychic powers Cannot have the same saga Link to comment https://bolterandchainsword.com/topic/221257-uniqueness-question/#findComment-2643619 Share on other sites More sharing options...
