Way1and Posted February 6, 2011 Share Posted February 6, 2011 Sorry if we've been here before. the Search button doesn't like me tonight. Picked up a pin vice at the store but there weren't any separate bits on the rack and it didn't come with any. What sizes do you commonly use on your gun barrels? Can I pick them up at the hardware store or do I need to find another hobby store? Link to comment https://bolterandchainsword.com/topic/221763-pin-vice-drill-bits/ Share on other sites More sharing options...
Khestra the Unbeheld Posted February 7, 2011 Share Posted February 7, 2011 For bolters, I use #74, which is .023" diameter. Link to comment https://bolterandchainsword.com/topic/221763-pin-vice-drill-bits/#findComment-2649405 Share on other sites More sharing options...
DV8 Posted February 7, 2011 Share Posted February 7, 2011 Check out your local hardware store in the tools section. Dremel sells a wonderful drill bit set that has all the bits you should need for drilling most of your models. The smallest is the perfect size for the bolter barrel ports, and the largest is perfect for space marine bike exhausts, just to give you a range. Bonus is that you get an excellent bit holder that ensures you won't lose your drill bits. And it's relatively inexpensive too! The set runs about $6 CDN at Home Depot here. DV8 Link to comment https://bolterandchainsword.com/topic/221763-pin-vice-drill-bits/#findComment-2650274 Share on other sites More sharing options...
averykess Posted February 7, 2011 Share Posted February 7, 2011 which pin vice did you get? Sometimes they have bits stored in the other end of the handle. Link to comment https://bolterandchainsword.com/topic/221763-pin-vice-drill-bits/#findComment-2650451 Share on other sites More sharing options...
hmk17 Posted February 7, 2011 Share Posted February 7, 2011 Check out your local hardware store in the tools section. Dremel sells a wonderful drill bit set that has all the bits you should need for drilling most of your models. The smallest is the perfect size for the bolter barrel ports, and the largest is perfect for space marine bike exhausts, just to give you a range. Bonus is that you get an excellent bit holder that ensures you won't lose your drill bits. And it's relatively inexpensive too! The set runs about $6 CDN at Home Depot here. DV8 +1 to this. And the bits have proved far stronger than anything a GW/P3/Army Painter pin vise will come with. Link to comment https://bolterandchainsword.com/topic/221763-pin-vice-drill-bits/#findComment-2650601 Share on other sites More sharing options...
Way1and Posted February 7, 2011 Author Share Posted February 7, 2011 Ah, Dremel! Whyn't I think of that? Avery, just a cheesy no-name one. i already checked the handle. :P Link to comment https://bolterandchainsword.com/topic/221763-pin-vice-drill-bits/#findComment-2650762 Share on other sites More sharing options...
