Sevrin Loth as BA Scriptor
Lanfear
Heya ;)
My new Scriptor just finished, so i wanted to share the miniature with you :no:
http://www.coolminiornot.com/271036
Thanks for the input you gave me :)
Oh....my....god. Thank you for giving me something to do with my Sevrin Loth model. Phenomenal. I gave it a 9.
I would like to point out that the jump pack doesn't look like the Sanguinors at all. Atleast to me. Did you do some weird positioning with his wings or does it just look like that because of the awkward camera angle?
Also: I'm petitioning for a tutorial on assembly. I know it can't be that hard, but I'm really a fool when it comes to converting metal, especially when I'll be putting it on resin.
thb, its just plain easy.
take your side cutter and remove the parchments comming out of the jump module. There is a cable coming down from the backpack, there you need to be carefull, but its not hard. you need to file it into the right shape. Dont worry if it isnt perfect, its on the downside of the backpack, and it will not be seen on the table, you need to flip him to see this part :P
to remove the star on the top, just remove it with your side cutter and file the surface till its even.
now the tricky part.
take the Red Scorpions shoulder pad and file it even till you have the clean circle, remove the scorpion fully.
After that, you need to form a drop with greenstuff, and bring it onto the circle. let it dry and then you can file it into the right shape if you need to adjust it.
thats all :)
