Alphz Posted February 11, 2011 Share Posted February 11, 2011 I'm completely perplexed as how to achieve model the tiny little studs that space marines commonly sport on their equipment and armour. Not the heresy studs but the even smaller ones that are one extra armour plates, boltguns, the shoulder pad bandings. They just so damn tiny... If you need I can try find pictures of what I mean. But basically just check out a bolter and those tiny little nobs in the corners are what I'm basically after. Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/ Share on other sites More sharing options...
ravenguard2010 Posted February 11, 2011 Share Posted February 11, 2011 I've managed this kind of thing before by getting a cocktail stick, putting it point first into some undiluted PVA so that there is a bit on the tip. Use that to add a tiny blob. Leave it to dry, and it should look like a little rivet/stud etc. Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2655890 Share on other sites More sharing options...
Brother Nihm Posted February 12, 2011 Share Posted February 12, 2011 And we did not check the Librarium before asking, because? ;) http://www.bolterandchainsword.com/index.p...showarticle=716 There are of course many ways to do it, but that's one. Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2656028 Share on other sites More sharing options...
Alphz Posted February 12, 2011 Author Share Posted February 12, 2011 I did Brother Nihm! Those are the 'big studs'... Where as I am after the little ones you find on extra armour plates, the bolter or backpacks. These little fellas (on the backpack) Credit of picture is to Sioka from this thread Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2656071 Share on other sites More sharing options...
Brother Nihm Posted February 12, 2011 Share Posted February 12, 2011 Ahh, You can buy thin plastic rod and file them so that they are round + cut them. or Use small drops of glue as has been mentioned. or If you can, get your hands on a rivet maker used for miniature tanks etc. Greif used to make some, but they went out of business. Maybe someone out there know of a replacement. or Roll up small balls of greens stuff and cut them in half. Requires a scalpel and steady hands. Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2656079 Share on other sites More sharing options...
Alphz Posted February 12, 2011 Author Share Posted February 12, 2011 Yes rivets! thats the word I was after. Hmm yeah, I have tried the greenstuff roll and then slicing. But I find it very hard to get it thin enough to replicate the rivets and then they are squareish. I could try the ball idea but that would make it very challenging to achieve consistency. I was hoping there was a good method to achieve consistency. Ball point pen maybe?? Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2656083 Share on other sites More sharing options...
Kurgan the Lurker Posted February 12, 2011 Share Posted February 12, 2011 http://www.scalehardware.com/miniature-rivets-c-10 Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2656106 Share on other sites More sharing options...
Tanhausen Posted February 12, 2011 Share Posted February 12, 2011 You guys know the Britta water kettles? The filters are full of tiny balls that happen to be perfect for what you want to do ;) BTW, if that pic is yours, thats a very good looking true scale! Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2656263 Share on other sites More sharing options...
Alphz Posted February 12, 2011 Author Share Posted February 12, 2011 http://www.scalehardware.com/miniature-rivets-c-10 I'm astonished they make rivets that small... Thanks Kurgan, I might actually go with that. Link to comment https://bolterandchainsword.com/topic/222186-how-do-you/#findComment-2656348 Share on other sites More sharing options...
