Segmentum Solar, Armageddon Sector Fleet List
obs0l3te
my guess is the cost involved in having to buy 2 seperate fleets. same as with 40k you generally buy/play 1 army at a time :rolleyes:
also a pure space marine or a pure IN fleet is much easier to keep track off. with mixed fleets you have to keep in mind which vessels are space marine vessels which arent, etc.
thats not to say you cant combine lists though. its just more hassle :D
my take on it at least :)
Well I was thinking....
Master Of Fleet 3 Rerolls
Battle Barge (Insert Space Wolf Name here)
3X Strike Cruisers (Insert Space Wolves names here)
3x Nova (Insert Space Wolves names here)
3x Hunter (Insert Space Wolves Names here)
1x Gothic (Ship fought with Space Wolves in the Armageddon Wars, was destroyed wolves refitted it in honor of the Ships Captain)
2x Gladius (Insert Space Wolf Name here)
Comes out at 1500 points.
According to the list you dont' pay any extra for the Gothic.
i meant real life costs, as in money :HQ:
indeed you dont pay any additional costs for the vessels.
2 gladius frigates might not be that much use m8. only 1 needs to die for the squadron to be "crippled" and even full strength they wont do anything stellar. they might strip shields for the gothic and/or novas to fire thugh which does have some merrit.
speaking of which, may i ask why the single gothic? the only reason that i can see is "to have a lace-boat in my fleet" which is a thing that space marines lack to be sure. if its on its own however its an easy target for your opponent to take out. grouping it with a dominator or tyrant for some battery back up would seriously increase its usefullness.
that said i can see where youd have difficulties finding points to take anything out of your list and cant really comment much on that either...
perhasp the veterans can help you more on this?
well if your hell bent on taking a second cruiser theres a few things you can do:
*2 lunars, 12 weapon battery to each side and 4 lances to each side, 6 torpedoes each. very nice all-rounder and would add a nice punch to a marine fleet. can also upgrade to a nova cannon if you wish. also the cheapest option to take (except when you want a nova cannon though, then the dominator is cheaper)
*upgraded tyrant (or not) and a gothic. 10 weapon batteries on each side, 4 lances each side and 6 torpedoes each. these suffer abit if one (or both) get crippled, since all specific weapons are stuck 1 particular ship the lances are easily taken out (and eldar might take the tyrant out asap) other then that a nice combo, the ships compliment eachother well :lol:
*gothic and dominator. dominator has strength 12 batteries on each side (which incidentily is the same as the 2 lunars and more then the upgraded tyrant) and the 4 lances from the gothic. the nova cannon from the dominator is somewhat lost on the space marine fleet as theyre designed to close rapidly, whilst the nova cannon has to hang back to be effective. its a very nice punch at range though (if you hit)
firepower-wise all these combos are virtually identical. it depends on what kind of role you want your ships to fill in this list. the 2 lunars are however the most resistant to beeing crippled as their firepower is split evenly over the 2 ships. if you take a gothic and x ship and one becomes crippled you lost alot of firepower ;)
mind you ive ignored the dictator for this list as you dident list it yourself. space marines got their own fighers and assault boats in thunderhawks. if you want though bombers are nothing to sneeze at either and could fill a niche as well. just...even harder to pair up with another cruiser then those listed above here :;)
The reason so few mixed IN and SM fleets are seen is that you typically field a stronger fleet going all one or the other. If you look at IN, you can take a dauntless which is a rough equivalent of the SC for 35 points less than a Strike Cruiser which is the only Marine cruiser choice. Gaining access to the 6+ armor and Thunderhawks doesn't offset that you still have a light cruiser that's nearly as expensive as a full IN cruiser. Now there could be more argument for including the battlebarge in the fleet, but access to the Emperor means that it's far more efficient to just take that and leave the BB at home. I think the theory behind the fleet was to offset the drawbacks of the mixed fleet by allowing easier access to the higher firepower of the Armageddon and other CB's while taking more of the Strike Cruisers and the Endeavour class CL.
In theory, at least, you get one CB for every cruiser and if you take a large number of CL or SC you should have a pretty solid firebase. In practice I don't think that quite works out. For instance, lets look at a primarily SC fleet backed up by CB. Since you will have a fair number of AC from SC, we can drop the usual emperor and try the Oberon. I'll be using the FAQ 2010 points for the ships.
Oberon+ AB: 340
Armageddon: 235
Armageddon: 235
Armageddon: 235
Strike Cruiser: 145
Strike Cruiser: 145
Endeavour: 110
Admiral: 50
So what do we gain from this. We have the necessary 8AC and four of that is in resilient thunderhawks. Unfortunately, that leaves us with a squadron of 2 SC and we just don't have the points to fit in a third. That leaves us with a fairly weak 2x SC squadron and the odd man out with the Endeavour which I guess could sit with the CB's since it can't squadron with SC. Since we can't really max out too much on CB if we take a BB, we have to adjust down to this:
Oberon+ AB: 340
Armageddon: 235
Armageddon: 235
Tyrant+Range: 195
Strike Cruiser: 145
Strike Cruiser: 145
Strike Cruiser: 145
Admiral: 50
So basically taking a BB and mixing in SC, we effectively end up back with the 2:1 ratio for cruisers to CB and we don't really gain a whole lot compared to a traditional IN or Marine list. So what happens if you ignore the battleship? It sure frees up points but is it really enough to do anything different?
Armageddon: 235
Armageddon: 235
Armageddon: 235
Tyrant+Range: 195
Strike Cruiser: 145
Strike Cruiser: 145
Strike Cruiser: 145
Endeavour: 110
Admiral 50
That almost nets the 1:1 ratio but we still have to drop an Armageddon and a SC to fit it all in 1500 points so we are a bit low on AC and we've got NO bombers so again it's not a very solid list compared to either a traditional Marine fleet or an IN fleet.
Was excited there for a moment.. then realized i'm limited to Mars, Armageddon, Lunar, Tyrant, gothic, and Dictator.
and endeavour, endurance and defiant. Those are the only cruisers the list allows.
it can take every escort.
I may try the gothic/lunar combo out.. or duel gothics.
edit... Vaasih just posted after I wrote...
Both of those are real nice to... I may have to try one of them out as well.
So I managed to screw around with the list a little... and did this...
BattleBarge
3x SC
2X Gothic
3x Nova
4 rerolls
I'm going to grab myself 2 Rogue Trader Ships and make them into gothics I think so my marines will look different from my imperial fleet.
I really wouldn't recommend going this route. The marine fleet lives on its escorts and the IN fleet lives on keeping formation. What you have there is a mismash of the most expensive marine escort, too few IN ships to form the line, and far too many rerolls.
You have too few SC that you can afford to lose any to casualties which leave you bracing since SC are pretty easy to damage and your escort squadron is a too small for a marine fleet plus it really doesn't give much in return for the 150 points you are spending on it. Gothics aren't a bad choice, but why not take armageddons instead? At least then you get some battery support and your lances get boosted out to 45cm and 60cm.
Battlebarge
2x Armageddon
3x Strike Cruiser
3x Hunter
MOTF
It's still not what I'd call an awesome fleet, but at least it makes better use of your points.
The Armageddon list ratio of CA to CB is 1:1 instead of the normal 2:1, so, yes, what I posted is a legal list. The only time you have to take anything in a 3:1 ratio is if you are pulling a ship in via reserves. I'd suggest rereading the list rules on page 27 of armada. The only thing I've done different is use the new point values in the 2010 FAQ draft for the Armageddon.
