Plastic question
Three methods I have used in the past are:
Boiling water to soften the plastic, bend to shape, let cool and set.
Heat gun, same as water but works a bit faster.
Hair dryer set on high, like the heat gun but takes a lot longer.
In all 3, be careful not to overheat the plastic or you can lose detail.
Best to practice on a few pieces of sprue first to get the technique right, then appy it to the piece you want to bend.
