shdwcypher13 Posted February 17, 2011 Share Posted February 17, 2011 I ask because I don't them mentioned often in ba lists. So I started wondering to their usefulness and their field abilities. Never having used them myself I that I'd pole you opinions and thoughts in them. And if you do indeed use then in what numbers and load outs. If I like what I see in responses I may build a list around a unit of sterngaurd..... hell who am I kidding I'm planning on doing that anyways. ;) Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/ Share on other sites More sharing options...
Dhx711 Posted February 17, 2011 Share Posted February 17, 2011 Being a "collector" (have to have at least one of every unit in the 'dex) I made a squad of 5 SGV outta spare models (mix of tach and assault). I've fielded them once with 2 meltas and Tycho in a Drop Pod in a friendly game vs Orks. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662433 Share on other sites More sharing options...
ant1clock Posted February 17, 2011 Share Posted February 17, 2011 Five in a Razorback, 3 combi meltas, 2 melta guns, and a Sang Priest. Kill a transport assault the crap out of what comes out. It worked pretty well when I've played it. I built my Sternguard using MkIII iron armour marines from FW, I love the models so I field them all the time. ant1clock Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662516 Share on other sites More sharing options...
JamesI Posted February 17, 2011 Share Posted February 17, 2011 I built my sternguard out of DC models and some SG parts. Mine use a sergeant with a fist and combi-melta, 3 combi-plasmas and 2 normal guys. (Combi-plasmas were chosen because that's what I had at the time). I don't run them often, but they can be an effective unit. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662523 Share on other sites More sharing options...
shan vener Posted February 17, 2011 Share Posted February 17, 2011 the sternguard units that i use are complete overkill. 7 combi flamers, 2 heavy flamers, power sword/combi flamer 7 combi meltas, 2 multi meltas, power fist/combi melta :D Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662586 Share on other sites More sharing options...
prenelf Posted February 17, 2011 Share Posted February 17, 2011 dont mean to rob your thread but while were talking about sternguard im just wondering can they still use the different ammo types they have if you give them storm bolters? Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662612 Share on other sites More sharing options...
Whitefireinferno Posted February 17, 2011 Share Posted February 17, 2011 Nope no special ammo if you are using a Stormbolter Combi bolters are fine but a big No No with Stormies. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662623 Share on other sites More sharing options...
shdwcypher13 Posted February 17, 2011 Author Share Posted February 17, 2011 The build chart in the back under special rules states special ammo so is assume so. What do you guys think of a 5 man unit 2x heavy bolter 3x normal. Or combi the way to go wit sgv? Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662628 Share on other sites More sharing options...
Chaplain Admetus Posted February 17, 2011 Share Posted February 17, 2011 I've been running a unit of 7 in a pod with a regular melta, 3 combis, and a fist. Occasionally supported by a priest if I think he'll be of value with them. Works extremely well. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662633 Share on other sites More sharing options...
shdwcypher13 Posted February 17, 2011 Author Share Posted February 17, 2011 Nope no special ammo if you are using a Stormbolter Combi bolters are fine but a big No No with Stormies. Now does this apply to heavy bolters as well? Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662652 Share on other sites More sharing options...
Spam Monkey Posted February 17, 2011 Share Posted February 17, 2011 Nope no special ammo if you are using a Stormbolter Combi bolters are fine but a big No No with Stormies. Now does this apply to heavy bolters as well? Yes. They only weapon you can give them that still uses the special ammo are the combi weapons. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662677 Share on other sites More sharing options...
Dhx711 Posted February 17, 2011 Share Posted February 17, 2011 To build off of Spammonkey's post the 'dex states that the special ammo (if used) replaces the boltgun (regular or combi) profile for that marine's shooting phase. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662693 Share on other sites More sharing options...
Brother Captain Kezef Posted February 17, 2011 Share Posted February 17, 2011 A tactic I was planning to experiment with is 10 sternguard with combi-meltas in a pod. Drop the pod down on top of a unit I want dead then kill it. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662776 Share on other sites More sharing options...
prenelf Posted February 17, 2011 Share Posted February 17, 2011 dam if you could use the ammo with the storm bolter i would use a man man unit every time how awesome would it be to have two 30" str4 ap4 shots every time you move you would do so much damage. I also wish they had a type of ammo something like shredder rounds str4 ap- assault 4 range 6" maybe i think that would be awesome Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662780 Share on other sites More sharing options...
Whitefireinferno Posted February 17, 2011 Share Posted February 17, 2011 I fail to see how you think that would work since the Special Issue ammo changes the Profile to Rapid fire anyway since there is no such thing as assault 2 rapid fire. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662799 Share on other sites More sharing options...
Emperors Immortals Posted February 17, 2011 Share Posted February 17, 2011 I run them regularily as either 5-7 man - DP or RB, 2 meltas for general use or 10 man in a pod with max plasma - 2 melta if needed for furious first turn drop.Just make sure you cover the second option with a tac squad. Unfortunatly BA do assault teh best, so it kinda works poorly with podding or non-mech armies. HAving said that, my squad is a hit squad - targeting hive tyrants or nob squads fr a turn then if the y survive its all a bonus. I love sterngaurd personally. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662800 Share on other sites More sharing options...
prenelf Posted February 17, 2011 Share Posted February 17, 2011 I fail to see how you think that would work since the Special Issue ammo changes the Profile to Rapid fire anyway since there is no such thing as assault 2 rapid fire. i didnt think i was just asking because i never use them and i havent spent much time looking at anything to do with them Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662801 Share on other sites More sharing options...
Emperors Immortals Posted February 18, 2011 Share Posted February 18, 2011 Personally, and i dont want to cause offense, i see o swearing here. Also, its a fair question to ask -prenelf- but please be civil. Then again, im not a Mod................................................ Or else ask the ultras, they use stern heaps more then us. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662853 Share on other sites More sharing options...
prenelf Posted February 18, 2011 Share Posted February 18, 2011 i will ask questions as i please if you dont like them fair enough but i will still ask them i haven't played as much as most others so fours are a great place to find out things people are uncertain of, i did not know about the storm bolter and the ammo and i did not have my codex and saw the topic of sternguard so i felt like asking simple as. i am in no way interested in fighting with you there is no point in it. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662911 Share on other sites More sharing options...
SamaNagol Posted February 18, 2011 Share Posted February 18, 2011 In future, for reference, I would recommend you read your codex thoroughly. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662924 Share on other sites More sharing options...
shatter Posted February 18, 2011 Share Posted February 18, 2011 Grrr... If I'm away from my codex I would ask the community here for reminding or clarification of detail. Now then. Sternguard are overlooked because we have so many BA things to be excited about. Most lists contain a clear majority of BA specialities/C:SM differences. I've used them to great (actually literally perfect) success and think, despite their elite slot competition, that they're staggeringly powerful combined with magnafrags & SRs. While folks get all excited about high initiative CC attacks 'going first', nothing goes first in melee like the shooting phase does... and their shoot phase is impressive with the placement precision a SR can deliver. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662940 Share on other sites More sharing options...
JamesI Posted February 18, 2011 Share Posted February 18, 2011 I've removed several posts. There was nothing in prenelf's question that was inappropriate. Lots of posters have had the confusion as to whether or not special issue ammo works with stormbolters. Lets try to avoid responding with "just check the codex", or if you feel a question is inappropriate due to being somethign that can easily be looked up in the codex, just don't answer. Also, please report posts where you think someone has posted inappropriately rather than responding in kind. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2662985 Share on other sites More sharing options...
shdwcypher13 Posted February 21, 2011 Author Share Posted February 21, 2011 just because its still on my mind. and I'd love more input, what would be good builds for a Veterans lists, Vanguards and sternguards. How would they work together? And of couse how would you put up your list and at what points? yeah I know alot of questions but hell thats what this is for general. :lol: Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2666103 Share on other sites More sharing options...
d@n Posted February 21, 2011 Share Posted February 21, 2011 Im seriously considering running a squad as an elite unit hunter probably with 3xcombimeltas and 2xheavy flamers in a rhino or drop pod. The reason you see don't see alot of sternguards in BA list's is because there so many other cool stuff in the elite slots Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2666115 Share on other sites More sharing options...
Brother Kovash Posted February 21, 2011 Share Posted February 21, 2011 I've been using a squad of 10 with combi-plasmas/plasmaguns against other space marine armies, that AP2 wins a lot of fights before they even begin. And d@n is correct, my elite slots are usually filled already, but when I have the chance the Sternguard can put out some impressive firepower. Link to comment https://bolterandchainsword.com/topic/222674-sternguard-do-you-use-them/#findComment-2666149 Share on other sites More sharing options...
