Wolfsrage Posted February 22, 2011 Share Posted February 22, 2011 I've purchased a Predator online (it will arrive soon-ish, hopefully). However, I was hoping to get an answer to this before it arrived. Does the Predator Kit come with the Razorback hatch? I.e. I can use the Assault Cannon from my Redeemer on it to make a Razorback (instead of another Predator as I originally intended). Link to comment https://bolterandchainsword.com/topic/223134-predator/ Share on other sites More sharing options...
DarKHaZZ13 Posted February 22, 2011 Share Posted February 22, 2011 Yes, the razor back hatch is what the turret for the predator is mounted on just don't glue the turret on and you can have both Link to comment https://bolterandchainsword.com/topic/223134-predator/#findComment-2668002 Share on other sites More sharing options...
Pearlay Posted February 22, 2011 Share Posted February 22, 2011 How about this... Rhino < Razorback < Baal < Predator < Whirlwind ? it's Pretty Simple, you can even use Stickytak or Handitak if your not good with magnets .... PARTS: http://i1221.photobucket.com/albums/dd461/40KJeff/DSCF0399.jpg Rhino/Razorback Depending on top Hatch you Use:[/b] http://i1221.photobucket.com/albums/dd461/40KJeff/DSCF0403.jpg http://i1221.photobucket.com/albums/dd461/40KJeff/DSCF0404.jpg Baal:[/b] http://i1221.photobucket.com/albums/dd461/40KJeff/DSCF0401.jpg Predator:[/b] http://i1221.photobucket.com/albums/dd461/40KJeff/DSCF0402.jpg Whirlwind:[/b] http://i1221.photobucket.com/albums/dd461/40KJeff/DSCF0400.jpg I Hope you Like and it gives you some Ideas ... I have 6 Rhino/Razorback Chassis Setups with parts for 3 Baal & 2 Pred & 1 Whirlwind Plus .. I have 1 DC rhino and 2 Vindicators .... Link to comment https://bolterandchainsword.com/topic/223134-predator/#findComment-2668082 Share on other sites More sharing options...
Pearlay Posted February 22, 2011 Share Posted February 22, 2011 Also forgot I have 2 Assault cannon from landraiders & 2 Flame Stormcannons set ups also & that all the Hatches are swappable. Link to comment https://bolterandchainsword.com/topic/223134-predator/#findComment-2668085 Share on other sites More sharing options...
Lord Scytha Posted February 22, 2011 Share Posted February 22, 2011 Pearlay, that is bloody brilliant!!! Pure genius!! Link to comment https://bolterandchainsword.com/topic/223134-predator/#findComment-2668117 Share on other sites More sharing options...
Vincent Black Shadow Posted February 22, 2011 Share Posted February 22, 2011 This is how I've used my Rhino chassis as well. I've gone a step further and can switch out different guns on a single turret piece. That way I can field either a HB or LC razorback with the one turret. I did the same with the predator turret, magnetizing both the TLLC and AC guns. With the assault cannon turret from the LRC/R kit, that's most of the options. I also intend to make a LC/TLPG turret or three soon, and may try out the TLHF turret at some point. All of my rhinos have a magnet on a crossbar (made from a piece of sprue) under the place where the turret/rhino top door goes. Magnets are placed on turrets based on where I want the turret to sit (towards the back or the front). I also have magnets for mounting HKs and for switching out hatches for pintle storm bolters. I need to figure out how to magnetize dozer blades, then I'm set! Link to comment https://bolterandchainsword.com/topic/223134-predator/#findComment-2668145 Share on other sites More sharing options...
