Sven's Thunderwolves
Darq Hunter
Last year when Dave Taylor posted his thunderwolves I was inspired. I started last year with one and I have been slowly getting more thunderwolves along with doing other things... playing games, painting other models, work, etc. Mjolnir posted his and well, I felt inspired to finally take pics of mine. One is finished and is sitting in the display case at my local GW but these three are still in progress. I used the Canis model as well but mine are different enough. You can definitely see the cues and influences Dave Taylor had on mine.
These are my ccw/bolter, MotW and melta TWs.
http://i.imgur.com/lYFO8.jpg
http://i.imgur.com/nyJ20.jpg
http://i.imgur.com/TLvfF.jpg
https://bolterandchainsword.com/topic/223192-svens-thunderwolves/
Tails are admittedly harder to work on than any other part. I agree, they aren't the best. The rearing up one will be fuller and fluffier. It's also a little weak where it joins with the body.
Thanks for the compliments on the jaw. He's my first conversion ever. In fact, these are my first forays into green stuff and converting.
Well then you truly have a knack for it. Fur is pretty hard to make it look like anything other than a bit of playdough with toothpick holes. Your manes look like you took the actual model and simply painted it green. Nearly indistinguishable from the GW fur.
