Tips on making a belt of Russ on the inq. scale marine?
Token
Having worn plate armor with a sword belt, I can tell you, the belt will move with the torso, so don't worry about which way his legs are facing.
There's that one bit in the SW box that looks like a wrestler's championship belt with the twin heads of Morkai on it. Know what I'm talking about? I'd say make it look similar to that. There's ease of use there as you can use the underside of the chest piece as your guide for the upper edge of the belt. Just model a boxy bit in the back for a buckle/fastener.
"Unlike the emblems of the Great Companies, the Great Wolf's emblem is always the same. This is the Wolf That Stalks Between Stars; the ancient badge of Leman Russ himself and the symbol proudly emblazoned on the Chapter's banner."
5E, pg. 14
I would attempt to place that badge on the faceplate/buckle of the belt if you're truly going for the Belt of Russ.
