BOBMAKENZIE Posted February 26, 2011 Share Posted February 26, 2011 http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0312.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0314.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0319.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0320.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0321.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0332.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0337.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0329.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0323.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0341.jpg http://i5.photobucket.com/albums/y196/Bobmakenzie/THawk/IMG_0343.jpg Link to comment Share on other sites More sharing options...
lee265 Posted February 26, 2011 Share Posted February 26, 2011 Thunderhawk from kitbash and I'm guessing lots of plasticard is awsome. Can I ask do you remember what material went into it? Link to comment Share on other sites More sharing options...
Slayer le Boucher Posted February 26, 2011 Share Posted February 26, 2011 By the looks of it my guess is: One land raider hull,One valkyrie kit,One stormraven kit and 2 rhinos hulls,lots of plasticard. Nice,very nice. Link to comment Share on other sites More sharing options...
verpine Posted February 28, 2011 Share Posted February 28, 2011 I like it, nice freehand. The middle section seems a bit streteched out, but it still looks great. I gotta say though, the cannon on top could use a lot more detail and love... Link to comment Share on other sites More sharing options...
Inquisitor Engel Posted February 28, 2011 Share Posted February 28, 2011 Not a bad effort at all! Well done! Link to comment Share on other sites More sharing options...
BOBMAKENZIE Posted March 1, 2011 Author Share Posted March 1, 2011 Thunderhawk from kitbash and I'm guessing lots of plasticard is awsome. Can I ask do you remember what material went into it? Assuming you wanted to do this conversion the only things you're really need are: Razorback, Rhino, Crusader, valk, storm raven. A couple packs of plastic card, a pack of plastic strips and a plastic tube. Plus a generous helping of bits. To be precise kits wise it would be... 1 Vindicator 1 Razorback 1 storm raven 1 valkyrie 1 Drop pod 1 set of Forgeworld rhino doors 1 Baal Predator 1 Land raider Crusader Parts wise... 4 rhino outter walls. 1 Storm Raven Turbine. 2 Storm Raven wings. 2 Valk Wings. 2 Razorback Lascannons. The Sponson tops & Cross bars & Sensors from a Land Raider(Hurrican bolter sensors) The missile pods from the Valk The forgeworld rhino doors with front plate trimmed down. A trimmed down Raven top and front. A trimmed down Valk rear the front carrier plate from the valk. A single BA emblem from the Drop Pod 2 Valk Turbines 2 2mm wide strips of plasticcard (the pre cut kind) 2 1/2mm thick sheets of plastic card. Some sprue for the inside... The magna grapple from the Raven. the top piece from the Vindicator. 2 of the decorative Baal pred pieces. The outter hull from the land raider. The landing gear from the Raven. Plastic tubing for the cannon. (I also used a single LotR movement tray to help support the plastic card in places. And some old binders to cut the winds out.) I like it, nice freehand. The middle section seems a bit streteched out, but it still looks great. I gotta say though, the cannon on top could use a lot more detail and love... The cannon I wanted simple. Its bound to wear out pretty quickly and have to be replaced. it seems alittle stretched cause its Thunderhawk Length but I've mounted the nose alittle differently. Link to comment Share on other sites More sharing options...
