Highborn Mergula Posted March 2, 2011 Share Posted March 2, 2011 so on the internet i've seen multiple blending videos. On the most videos they used acrylic then le's bursley uses oil paints on his Thunder hammers for blending. so i have some questions. 1.can you paint with oilpaints over acrylic or acrylic over oil? 2.wich is best for blending? 3.wich oilpaints should i use? thats all Thx in advande //HB M Link to comment https://bolterandchainsword.com/topic/223792-oil-paints-for-blending/ Share on other sites More sharing options...
KAINE-77 Posted March 2, 2011 Share Posted March 2, 2011 Heya, Well, I used to use oil and acrylic paints when I was at Art College, and you can paint over them in any combination... Oil's are more 'maintenance' and hard work... That's my opinion, but got beautiful effects on canvas... But, Oil paints take a lot longer to dry and need White Spirit and aclohol/flammable cleaning products, where Acrylic paints are water based and non-poisonous! But my experience comes from traditional 'Artist's' oils... Would be interested to see the blending videos, do you have a link? Really intrigued by this! Link to comment https://bolterandchainsword.com/topic/223792-oil-paints-for-blending/#findComment-2676010 Share on other sites More sharing options...
KAINE-77 Posted March 2, 2011 Share Posted March 2, 2011 Just checked out the tutorial you mentioned... So, seems there are now water based Oil paints about, hehe, showing my age I guess! :) The tutorial vid pretty much tells you what you need to know, but it seems that the time it takes the Oil Paint to dry is the advantage when blending (as acrylics will dry out way too fast), Just make sure you find the Water-based type! Gotta admit, this something I'm gonna try, so thanks for the heads up! Link to comment https://bolterandchainsword.com/topic/223792-oil-paints-for-blending/#findComment-2676031 Share on other sites More sharing options...
Highborn Mergula Posted March 2, 2011 Author Share Posted March 2, 2011 Here's some blending with acrylics. ;) so waterbased oilpaints next :) Link to comment https://bolterandchainsword.com/topic/223792-oil-paints-for-blending/#findComment-2676033 Share on other sites More sharing options...
